Hobbywing 90A ESC
Followers (5)
Hobbywing 90A ESC
A latching relay has two coils, one to operate the relay (on) and one to release it (off). My latching relay has 5 connections. It is designed to be mounted onto a circuit board. Two large pins for the relay contacts (50A) and three small pins for the two coils. On the side of the relay was information which indicated that the common connection to the two coils should be the +ve connection. The diagram shows the circuit wiring. The on/off switch I used is a centre off toggle switch, sprung loaded each way from centre. Pushing one way applies power to one relay coil, switching the relay on. Pushing the toggle the other way applies power to the other coil, switching the relay off. These are usually described in catalogues as ' (on) - off - (on) ' switches.
I didn't use a circuit board to mount the relay. I simply soldered wires to the pins, and insulated them with heatshrink.
Graham93
Hobbywing 90A ESC
"If I want to switch it with a sensibly sized switch,presumably I would need a relay,as 90A @12V is a pretty heavy load."
I use a 50A latching relay together with a blade fuse in my Crash Tender to switch the ESC power. Using a latching relay means the relay doesn't continually draw power, only a short pulse to switch it on, and another to switch it off. The relay has two coils, one for on and one for off. These are activated using a small centre off spring loaded toggle switch mounted under the sliding hatch on the forward cabin roof. Push one way for on, and the other for off. The second switch is for the separate receiver/auxillaries battery.
Graham93
Hobbywing 90A ESC
The boat is the model that Robbob has a build blog on the site,a 46" crash tender.It is heavy and needs a realistic scale speed.
Motor is Overlander thumperT4260/06.
Cheers,John
Hobbywing 90A ESC
I don't use a switch but have a removable blade fuse.
As said I doubt you will use 90 Amps!(Check the maximum draw at the motor not stalled!) You want it to fail before stalling The cable would be horrendous👍👍
Hobbywing 90A ESC
The Seaking series generic manual simply shows that you CAN connect two batteries in series on the higher power ESCs used with motors that can run on higher voltages.
Or you may want to use two lower voltage LiPos to spread the weight , e.g. port and starboard.
It doesn't mean you must! 😉
Without knowing what boat and motor you are using it with we can't say what is adequate or not🤔 Or what switch current rating you would need.
I doubt you will ever be using 90A. That is only the max continuous current rating of the ESC.
Check your motor specs and see if it gives the current drawn at maximum efficiency.
That will give you a good guide👍
DON'T FORGET A FUSE BETWEEN BATTERY-(IES) AND ESC!!!
I also have some car blade type circuit breakers (Halfords etc) which switch off automatically in emergency (stalled motor!) or can be used as a manual ON/OFF switch.
I think they go up to about 50A or so, which might be enough for your application.
Are you going racing??
Hope that helps.
PS I get my Hobbywing Quicrun ESCs on a 'fast truck from Krick', last two arrived three days after ordering 😊
Hobbywing 90A ESC
Couple of queries: The wiring diagram shows connections for TWO
Lipo batteries in series.Why? when one 4S with enough capacity @ 14V is surely adequate?
Any advice would be treasured!
Liked by
Loading…
