Hi Martin, Dead on DPST is correct👍👍 #5 6 years ago Switch Hi Martin, Dead on DPST is correct👍👍 Only old in years not mind or soul. Liked by Martin555
Hi Rick, To switch both wires i think the switch is called a DPST (double pole single throw) There are all sorts of switches that will do different jobs. Martin555. #4 6 years ago Switch Hi Rick, To switch both wires i think the switch is called a DPST (double pole single throw) There are all sorts of switches that will do different jobs. Martin555. If it looks right it probably is. Liked by RNinMunich and Peejay and 1 other
Thanks Martin How would I do both sides not sure what switch it would take to do this. Rick #3 6 years ago Switch Thanks Martin How would I do both sides not sure what switch it would take to do this. Rick Liked by Peejay and Martin555 See all
Hi Rick, Normally it is the red wire. It also depends on what type of switches you use as you can switch both wires at the same time. Martin555. #2 6 years ago Switch Hi Rick, Normally it is the red wire. It also depends on what type of switches you use as you can switch both wires at the same time. Martin555. If it looks right it probably is. Liked by Peejay
To set up a switch for the battery which side red or black is better or is ether side OK. Rick #1 6 years ago Switch To set up a switch for the battery which side red or black is better or is ether side OK. Rick Liked by Ianh and Martin555 See all
