Propeller shaft
Started by Maverick
20 replies 13 likes Last activity: 5 years ago
Propeller shaft
I think you need to check your locations! 🤔
Propeller shaft
Price would be $25 plus postage. You probably should PM me at my e-mail:
ghiltz01@hotmail.com
Feel free to also join my FB page:
Greg's Model Boatyard
Propeller shaft
How much for a 12" shaft tube, and about15"x 5mm shaft aplease?
Propeller shaft
Enjoy Alberta! We did the Ice Field Parkway drive Canmore to Jasper in 2016.
Liked by GregHiltz
Propeller shaft
Been there in Canmore, best Bison, Blue Cheese burger ever. But, not at Tim Horton’s.
Propeller shaft
Well at least I got the correct state, I thought it was near Jaspers rail yard
Propeller shaft
Actually stepping outside Tim Hortons in Canmore, as we visited daughter in Alberta.
Good catch!
Propeller shaft
As Dave correctly pointed out, there are different materials and styles of thrust washers. As you have not indicated what the application is, we can only give general guideance. The requirements of scale models is quite different than say gas or high speed electric monos and hydros. Those will often require and use three part caged ball bearings. On this side of the pond Octura came out with those first,( i am dating myself) but here are quite a few available brands now.
Liked by Maverick
Propeller shaft
Hi Maverick
I use brass or stainless steel but on a scale model Nylon would be ok.
As ToraDog says they are there to protect the prop and UJ but also to protect the motor. When going forward the prop shaft is pushed against the end of the proptube and will also push the motor shaft if not supported. The opposite happens in reverse so the washer acts as a cushion at both ends of the prop shaft. The bearings in motors are designed to support the rotating prop shaft and have little or no support in the horizontal plane.
Liked by Maverick
Propeller shaft
I supply stock 12" length Shafts with ShaftTube, plus custom make any length needed, threaded for 4mm, 5mm, and 3/16" prop threads.
My shaft lengths are measured in overall length.
Liked by Maverick
Propeller shaft
I am assuming that you are asking about the washers...? they should fit the shaft, ie, 1/8th " shaft get a 1/8th" washer. The washer should be the sacrificial piece so that your prop does not suffer wear, likewise the u-joint and or shaft lock/reverse thrust bearing on the inside should be protected from wear as well. Personally, and this is because my shaft do not turn at really high rpms, but do bear significant thrust loads, I use nylon washers. Cheap and easy to replace. others will have their own solutions so you should continue to ask around and find what suits your needs the best.
Liked by Maverick
Propeller shaft
How big and what are they made of please?
Propeller shaft
Great point Dave, I missed that. I put a thrust washer behind my props on large models as well.
Propeller shaft
Agree and don't forget the thrust washers between the prop and shaft and u-joint and shaft.
dave
976
Liked by ToraDog
Propeller shaft
Kinda, sorta, yup. The easiest way to measure it is to mount, even temorarily, your motor with it's u-joint in place. Then, measure from the prop, as previously mentioned to the inside of the u-joint.😀
PS: measure three times, cut the shaft once.........don't be like me and buy extra shafts🤣
Liked by Maverick
Propeller shaft
So basically, the case runs from the prop to just into engine Bay, and so long as the shaft is long enough to go from the prop to the universal joint leaving some exposed is correct.🤔
Propeller shaft
Well, no. The required length would include that part of the shaft that is inserted into the propellor, extending thru the keel into the engine compartment, and further extending onwards to and into the universal joint, figuring that the U-joint is properly positioned relative to the engine/motor mounted position. I hope that makes sense.
Liked by Maverick and dave976 and
Propeller shaft
Is a required propeller shaft length, measured from the actual propeller to where it enters the engine Bay having passed through the keel.🤔
Liked by Colin H
