Current Website Support
85
Contributors
27
Subscribers
You are Not Registered
Subscribe for your gold medal ๐Ÿ…
Until Cancelled
ยฃ1
ยฃ2
ยฃ3
ยฃ5
Donate for your silver medal ๐Ÿ…
12 Months
ยฃ10
ยฃ15
ยฃ50
    Login to Remove Ads
    Followers
    flysky transmitter throttle control vey sensitive
    by alfiesmail ๐Ÿ‡ฌ๐Ÿ‡ง ( Able Seaman)
    ๐Ÿ“ฃ
    Click To
    Follow
    14 Posts 13 Replies 1 Photo 7 Likes
    alfiesmail
    Able Seaman
    ๐Ÿ“ flysky transmitter throttle control vey sensitive
    Online: 5 months ago
    Now I need to squeeze all this kit into the back of the boat as Iโ€™ve decided not to have an opening in the middle of the deck as its got a camber on it as it follows the shear stake and getting a lid to seal on a curved deck would be difficult it would mean having to make a hatch way that stands up like a real hatch and I donโ€™t have the skills to make something like that and have it turn out square
    Alfie W-J
    Lieutenant
    Online: 1 day ago
    Yes the mixers work with whatever you want. Glad you have now achieved a working solution that meets your requirements
    Dave976
    alfiesmail
    Able Seaman
    Dave i have used your mixes but using channel 2 instead of 3 as master to use the RH stick for everything
    1
    Alfie W-J
    alfiesmail
    Able Seaman
    What i did was change the channels in the mixes replacing chl 3 with 2 and now every thing is controlled by right hand stick, including rudder the neutral position problem has gone and i will use the left hand stick for the bow prop which was on VarB which was a little awkward.
    Thanks to every one for help and Advice
    Alfie W-J
    BobbyN
    Leading Seaman
    Country: ๐Ÿ‡ฆ๐Ÿ‡บ Australia
    Online: 21 days ago
    I still think the twin throttle upgrade to the Flysky is a good option. There is some additional cost but it is a simple and reliable solution. I have had one of these for five years and it works well.
    2
    Lieutenant
    Online: 1 day ago
    Hi alfiesmail
    I did reply to another member on how to set up the FS-i6s for dual motor control and repeat the post:
    Finally found some time to write up the procedure to program the FlySkyi6. Hopefully this will help you decide a way forward to control your twin props. The percentages I have used in the mix functions are more for guidance than hard and fast rules as different models and motors will benefit from some fine tuning.
    FlySky Fsi6 โ€“ Using Mixing functions
    Before commencing set your Tx to the settings I had on my TX
    SYSTEM
    Model โ€“ I suggest selecting a spare model and naming it Mixing until you are happy with the settings
    Type โ€“ Airplane or Glider
    RX setup โ€“ settings suitable for your equipment ie it will not affect the mixer
    Trainer mode โ€“ off
    Student mode โ€“ off
    Sticks mode- Mode 2
    SETUP
    Reverse โ€“ all normal
    End Points -all 100%
    Display โ€“ Select this to see the individual channel out puts and the effect of Chanel 1 via the mixer on channel 3 and 5.
    Aux channels Channel 5 โ€“ none
    Subtrim โ€“ all centered
    Dual Rate โ€“ Ch1 Normal Rate 100% exp 0
    Throttle Curve โ€“ Normal L 0% 1 25% 2 50% 3 75% H 100%
    Mix โ€“ this will link channel 3 and 5 and mix Channel 1 with channel 3 and 5
    Mix#1 โ€“ On Master Ch3 Slave Ch5 Pos mix 100% Neg mix 100% Offset 0%
    Mix#2 - On Master Ch1 Slave Ch3 Pos mix 50% Neg mix 50% Offset 0%
    Mix#3 - On Master Ch1 Slave Ch5 Pos mix -50% Neg mix -50% Offset 0%
    Elevon โ€“ Off
    V Tail โ€“ Off
    Switches Assign โ€“ not important
    Throttle Hold โ€“ Off.
    I am assuming owners of the i6 are familiar with the use of the buttons to operate the menu. I will mention for anyone new to the set that you need to save the settings on each screen by pressing and holding the Cancel button until the display changes. Yes the Cancel button. Took me a while to understand this logic when I first got the TX.
    Have fun and boldly go
    Lieutenant
    Online: 1 day ago
    Hi alfiesmail
    There is no need to buy any extra controls with the radio set you have.
    As you are using two Esc's you need to use one channel for each Esc. Say Channel 3 and five. You then use the mix functions built into the FS-i6s to mix channel 3 with channel 5 so that your throttle stick controls both channel 3 and channel 5. You then use another two mix functions so the the Rudder (channel1) is mixed with channel 3 and also with channel 5.
    I did post a very similar resume on how to actually set up and I use this exact same Tx on several models with no problem, even with no centering spring.
    If you need more help please ask
    Graham93
    Rear Admiral
    Online: 2 days ago
    I had the same problem using the fs-i6 on a single prop model with fwd and reverse. Fitting the self centring kit cured the problem ๐Ÿ‘
    Graham93
    alfiesmail
    Able Seaman
    tried to alter the sticks from mode 2 to 3 but i could not figure out how to change the mixes i think i will go for the kit
    Alfie W-J
    Softie
    Able Seaman
    Online: 20 hours ago
    Is the throttle stick sprung to centre?
    If it isnโ€™t then you havenโ€™t much chance of finding centre off.
    The kit for the i6 is available from China for a few pounds but make sure you order the one with 2 dowel pins in the kit because you do need them both.
    Are you using 2 escโ€™s ?
    Show 4 More Posts
