Β£2.50
Β£4.50
Β£6.50
Valid 12 Months
Β£25
Β£45
Β£65
    Prop shaft be waterproof..
    14 Posts Β· 4 Followers Β· 4 Photos Β· 7 Likes
    Began 7 months ago by
    Petty Officer 2nd Class
    Latest Post 6 months ago by
    garyp
    πŸ‡¬πŸ‡§ United Kingdom
    πŸ“ Prop shaft be waterproof..
    Online: 3 months ago
    😊 View Profile
    πŸ’¬ Send PM
    πŸ’΅ Gift Membership
    Thank you will do ..
    Gary Pressman
    Len1
    Warrant Officer
    πŸ‡ΊπŸ‡Έ United States
    Country: πŸ‡ΊπŸ‡Έ United States
    Online: 16 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    I pack the shroud (tube) full of grease and any excess is pushed out when you insert the shaft. I use Sta-Lube marine grease
    LEN1
    garyp
    😊 View Profile
    πŸ’¬ Send PM
    Ok.. Now do I pack the shroud with grease...Or do I smear the prop shaft with grease or do I do both...?I have never done this before...Also do I pack the shroud all the way inboard or do only pack say an inch or so from the prop...Please can you advise....
    Gary Pressman
    garyp
    😊 View Profile
    πŸ’¬ Send PM
    Thank you.will do
    Gary Pressman
    MouldBuilder
    Vice Admiral
    πŸ‡­πŸ‡Ί Hungary
    49 Views Β· 2 Likes
    Country: πŸ‡­πŸ‡Ί Hungary
    Online: 4 seconds ago
    😊 View Profile
    πŸ’¬ Send PM
    Hi Gary.
    These would do the job.
    Search for β€˜nylon washers’. There are a lot of sellers who sell multiple sizes, usually giving you two choices, size and quantity.
    You need M4 which will usually have a 4.3mm diameter hole. The next choice is quantity. You will notice that it costs less to buy more, sort of, so 20 should be about right.
    Peter.
    garyp
    😊 View Profile
    πŸ’¬ Send PM
    Thank you.Will do..
    Gary Pressman
    Len1
    Warrant Officer
    😊 View Profile
    πŸ’¬ Send PM
    For what its worth, I use Sta-lube Marine grease. It seems to have the right consistency and it come it a grease cartridge so you can use a grease gun if you have added a zerk fitting and you can also just scoop some out and hand pack.
    LEN1
    garyp
    😊 View Profile
    πŸ’¬ Send PM
    Thank you Can you name them so I get the correct ones..as in nylon my shaft is 4mm I'm no use
    Gary Pressman
    garyp
    😊 View Profile
    πŸ’¬ Send PM
    Thank you..Where are the bearings?The shroud is just hollow....The first option is the best. Now some genius Loktited the prop onto shaft so an added complication....Please can you help...
    Gary Pressman
    MouldBuilder
    Vice Admiral
    πŸ‡­πŸ‡Ί Hungary
    😊 View Profile
    πŸ’¬ Send PM
    You can get the washers on eBay from the β€˜bolt shop’. I also use these nylon washers.
    Show 4 More Posts
