Brushed motors
Started by TerryH
2 replies 4 likes Last activity: 3 years ago
Brushed motors
Well found out eventually.. So on brushed motors the higher the T value the lower the revs and higher the torque. So on that I'm going for a T27 see if that works
Brushed motors
A 80 turn is the slowest at 5,500 rpm on 7.2 volts ( unloaded). If using a 60mm 3 blade prop and a 50mm 4 blade prop.
ESC a Quicrun 60Amp with just straight forward/ reverse.
Liked by Doogle and RodC and
Brushed motors
I need to buy a brushed motor for a 35" tugboat . So question is I'm buying a 550 motor but what T value for a tugboat
Regards Terry
Liked by Colin H
