Leaking DF65
Of all the advice received the simplest and best was to blow into the drain hole whilst brushing soapy water all over the hull. Quick, easy, no dismantling required, and immediate indication of where leaks are.
In my case all the leaks are around the control exit grommets at the stern. None elsewhere. 😉
