Motor size help
Motor size help
My Amsterdam is on 24volts with a single T24 motor from Mobile Marine, I use an Electronize ESC, they are rated to 24volts and 40 amps, they are not the smallest but mine are possibly 15 years old, so good value, easy to set up, almost plug and play, ( single adjustment to align the full movement on stick and motor.
Electronize highly recommended
Motor size help
Motor size help
It is a johnson motor the type that goes into electric drills, I tried it out and it spun very fast, I will have to look on the website and see if I can find out more.
Stan
Motor size help
Hook up to a watt meter and try not to exceed the motors max, probably about 65 watts.
Going to be trial and error, hull type, propeller and desired speed.
Motor size help
Liked by
Loading…
