SAIL CONTROL AND ADJUSTMENT SYSTEMS FOR SCALE MODELS
Started by AlessandroSPQR
49 replies 108 likes Last activity: 7 days ago
#48 13
@ColRay I don't remember the original source exactly anymore.Pict
2-4 my construction. Lever arm are free . I use a Hitec HS-765 SERVO SAIL ARM Servo for the mainsail sheet. I accidentally found the source for semaphore jib -see.
Main principle: if it is not broken - don't repair It!
Liked by AlessandroSPQR
#47 18
@tomarack
Thanks, I use the lever-servo on the DF65 &RG65.
To get the scale effect on the schooner mainsheet, the sheet travel is 260 inches. It takes 10 seconds to go in or out. The foresail is about a quarter of that
Liked by AlessandroSPQR and hermank
#46 19
@tomarack
Hi Tomarack, thanks for sharing your thoughts, photos, and diagrams.
Personally, I have some reservations about using a sail arm servo instead of a drum winch; for the time being, I’ve opted for the drum winch because I didn't have enough room in the hull for the arm's full range of motion.
To make the best use of space, you really need to mount it off-center, just as you did. I’m not a fan of asymmetrical layouts and avoid them whenever possible.
Of course, that’s just my personal preference; in your case, the arm servo setup is highly effective and functional—well done.
Regarding the other issues we’ve discussed in detail, I noticed that you have a rather large rudder.
Hello Tom just love the Thames Barge, I had thought about sailing my barge , then because of the age of the model , she's over 50 years old thought better of it.
I could be using the arm and servo system on my latest project the two masted 3D printed model Col
#42 25
@RossM
Hi,When I built my first model of a Thames sailing barge, I used a sail winch and a lever servo for the jib and vangs. For my subsequent models, I used only lever servos for the mainsails and a "semaphore jib" mechanism for the jib.
Ultimately, it is a matter of personal choice. I was recommended an lever arm servo, and I used it on my boat for both the mainsail and the top of sprit (vang). I find that there is real strength in simplicity—the sail can be quickly adjusted to the desired position, something a standard winch simply does not allow.
Pict nr 4 - Peter Simmonds model TSB Veronica (GB)
5+6 - my TSB Capricorn
Tom
#41 28
Good evening to all ship modelers.
I will now move on to discuss mainsail control systems.
First, I’ll cover the system I used myself; then, a possible alternative solution; and finally, the highly efficient methods used by two excellent ship modelers who run a very interesting YouTube channel.
The first diagram shows a very simple mainsail control system.
I have included photos and videos so you can see how it works.
The sheets do not tangle—so the system works well in that regard—but the issue of tacking remains.
As you can notice, the control system for the mainmast boom differs slightly from the one used for the foremast boom.
On the foremast boom, the end of the sheet is anchored to the deck (where I adjust its length); the sheet runs beneath the boom through small eyelets, then descends alongside the mast and enters the deck through a small hole right next to the mast base. Below deck, it reaches the winch via a system of pulleys.
On the mainmast boom, the end of the sheet is attached directly to the boom itself; from there, the sheet goes straight into a hole in the deck. Below deck, it reaches the winch via a system of pulleys.
In the next post, I will present some alternatives to this setup.
@AlessandroSPQR Thinking further;
This comes with a limit. The sail can not swing past the holes on either side of the deck, where the sheets enter the deck. This would best be used as the lowest jib of many jibs. The upper jibs can swing out further on their own servos.
If you are looking to power the jib to the other side of the deck this will help.
#38 33
@AlessandroSPQR
First: the concept of 2 winches attached to the same drive, from my STAYSAIL WINCH. If you blow up that photo to maximum and look at the 2 lines off the 2 winches, you will see one line comes off the top of the drum the other line comes of the bottom of the other drum. Too big for what you want
Second: the idea of stacking 2 sail drums to a servo.
The basic theory is that the drums work opposite directions to each other. One drum pulls in while the other pays out
Liked by hermank and ColRay and
#37 34
@RossM
Thanks for the idea, Ross.
If you can make a sketch (even a rough, freehand one—no need for it to look polished), it’s easier to visualize and remember.
@AlessandroSPQR
Sorry nothing in my files
The short video I made on the STAYSAIL does that. One side slacks off while the other side draws in
IDEA:
Use the basic drum servo eg 3 and a half turns
Instead of my large motor driven winch, STACK 2 drums on the servo, instead of the usual one, lower drum goes out to port, upper drum goes out to starboard
#35 38
I believe that a scale boat or ship capable of executing a sharp turn using its rudder will have no issues with the systems described so far.
However, on some models, the rudder isn't large enough, so it might be helpful to assist tacking and gybing maneuvers using the sails.
The diagram shows a possible control system for the jib (or jibs) using two winches instead of one.
When the boat is sailing on a port tack (with sails positioned on the starboard side), the sheet on the port winch will be fully extended, meaning it has no effect on the jib's control or trim.
Conversely, the starboard winch's sheet will be adjusted according to the point of sail (fully sheeted in for close-hauled, fully eased out for a broad reach or running downwind).
When executing a tack, the rudder will try to bring the bow to port to switch to a starboard tack.
By fully easing the starboard sheet and sheeting in the port one, the jib is forced to the other side—not just by the wind, but also by the winch's pulling force on the sheet.
Admittedly, there is a risk of the jib getting "back-winded" and the tack failing, but the sail will remain on the side we want.
I haven't tried this system yet; it would need to be tested in practice.
The hope is that by forcibly positioning the jibs and mainsails on the opposite tack (using the power of the winches), we can assist the rudder's action.
I can't say more until I've put it into practice.
...Sorry, I wanted to edit post #28 to add two more images, but as a basic member, I can't do that after 24 hours.
That’s why I had to create a new post.
Before moving on to the jib control system, I wanted to share a few systems I’ve come across.
I hope you, too, can contribute other diagrams and images to share.
I’ve noticed that to prevent the drum winch from causing line tangles inside the hull when the sails are eased, RC modelers almost always use a continuous, tensioned closed-loop system, assisted by a spring or elastic band (as shown in the attached diagrams).
The winch drives this main loop, keeping it constantly taut; the individual jib sheets are then attached to this loop and led up to the deck, significantly reducing the risk of fouling or tangling.
This is the system used, for example, by Gary Webb.
The renowned designer, modeler, and YouTuber Gary Webb (founder of Bearospace Industries and the popular YouTube channel Sail Tails: Building model sailing boats with Gary Webb designs) is famous in the RC modeling community precisely for his sail control system for scratch-built schooners (such as his celebrated Irene and Annie models).
Gary Webb’s system employs a single winch servo to control a continuous closed loop (known as a "racetrack loop") that runs from stern to bow beneath the deck.
All the schooner’s sails (mainsail, foresail, and jibs) connect to this single line via small clips or knots.
Many modelers use a dummy boom beneath the foresail, and some forgo having the jibs cross over the foresail.
The Robbe Valdivia system uses a rack of metal rings instead of a rope loop.
In all these systems, however, the jib can still be mechanically sheeted in by the winch. The winch merely facilitates and controls the easing of the sheet, but the force required to bring the jib into position comes solely from the wind.
The tack change will also be dictated by the wind.
Alessandro No the sail system on my Thames Barges was just a block and ring running over a deck horse starboard/ port, slight adjustments were carried out before setting sail Col
#26 47
@ColRay
Thanks, Col—you're too kind.
Have you ever worked on sail trimming systems? If so, I’d love to hear your thoughts and ideas on the subject.
P.S. Remember, we always need to keep our minds sharp. And racking your brain to solve a problem is excellent exercise—hahahaha.
#23 48
@RossM
Yes, it can be done, Ross—both with the system I illustrated and used, and with another method I have in mind but haven't yet put into practice (which I’ll post as soon as possible).
However, the overlap between the jib and the staysail must be minimal—kept to the absolute minimum—to allow the clew to cross over to the other side, passing over the forestay of the underlying jib.
@AlessandroSPQR
So it looks like you can bring your JIB TOPSAIL over the top of your JIB? That is also something I must be able to do. I like the route of the MAINSHEET. Where does it go after it goes BACK to the deck astern of the drum winch?
#21 49
To better explain the system shown in the diagram and described in post #17, I am attaching a few images.
The red arrows in all the images indicate the jib sheets.
The blue arrows in all the images indicate the mainsail sheet (for the mainmast). This is not relevant to the current discussion but is included solely to distinguish it and avoid confusion.
It is evident, then, that the same forward-mounted winch controls both the jibs and the mainmast sails.
The green circle indicates the fixed points on the deck where the ends of the jib sheets are attached.
The yellow circle indicates the tiny holes in the deck through which the two jib sheets pass below deck before being led to the winch drum.
In the final image, the yellow arrows with red outlines indicate these holes.
It may be hard to see, but the jib sheets pass through a small ring at the respective clews; they are not fixed there but are free to slide.
Liked by hermank and EdW and
#20 49
@RossM
I think so too, Ross; I believe you're right, even though I've never actually tested it myself.
However, I’d like to play devil's advocate for the drum winch. Compared to an arm servo, the winch takes up less space and, above all, controls the line more smoothly.
Good morning to all ship modelers!
I was looking for some videos I had seen of RC square-rigged sailing ship models (which are actually quite rare), but I can't find them anymore.
In the meantime, I will proceed with the sail control systems, moving on to the jib adjustment.
In real-life recreational boats, the jib has two sheets attached to the clew: one leeward and one windward.
When, for example, the boat is on a port tack (meaning the wind hits the left side of the boat first and the sail sets to the right), the windward sheet (in this case, the left one) is slack and does not affect the jib's trim. The leeward sheet (in this case, the right one), however, controls the trim: pulled in tight for close-hauled sailing and let out fully for reaching or running.
On a starboard tack, it is exactly the opposite.
The system I used [though I don't consider it ideal and would like to improve it for my next RC sailing model]
The first sketch (again, a quick hand-drawn sketch, though I plan to redo it better) shows a simplified top-down view of the system I used.
The sheet (red line) starts from a fixed point on the deck, passes through the jib's clew, and enters a small hole in the deck; from there, after passing through a few fairleads, it reaches the winch.
Note that the sheet is not tied to the clew but is free to slide through a small ring.
This way, whether the sheet is pulled tight or fully let out, the jib is free to move to the right or left (free to tack, in other words) depending on the wind direction. By operating the radio-controlled winch, the sheet can be hauled in or eased out to suit the desired point of sail (close-hauled, beam reach, broad reach, or running).
A quick clarification: in this specific case, I was controlling two jibs. Consequently, the sheets from the individual jibs entered through two separate deck openings and only joined up below deck into a single line that wrapped around the winch drum.
Issues associated with this system
Changing tacks (for example, when turning from a close-hauled course on one side to a close-hauled course on the other) is achieved solely via the rudder.
If there is sufficient momentum and the rudder action successfully turns the boat, the jib (or jibs) will naturally shift to the side opposite the wind source (just as on real boats).
With this system, therefore, there is no way to force the jib to the other side by operating the winch.
Once the jib has crossed to the other side, the sail is trimmed for the specific point of sail (close-hauled, beam reach, broad reach, or running) by hauling in or easing the sheet using the winch.
In this setup, hauling in (trimming the sheet) is driven by the winch's mechanical action, whereas easing it out (facilitated by the winch rotating in reverse) relies on the force of the wind.
This system could potentially use a standard servo with a control arm instead of a drum winch, though I have never tried that myself.
What do you think? What system have you used so far?
Alessandro Back in my Perth club model making days one of the guys had a box sail rigger and the yard arm was fixed and the mast would turn, from memory it worked fine Col
#13 60
The first sail control system I am considering is the one for the square sail.
I should note that I haven't actually built this yet, as the square sail on my previous model was fixed and could not be controlled.
In a real ship, the yard is controlled (shifted to the left or right) by running rigging known as braces.
The sail itself is adjusted using the tack and the sheet.
In modeling, we can simplify this by combining the controls for the braces and the tack/sheet.
The diagram (a quick sketch, though I plan to redraw it properly) shows the setup from an overhead view.
I envisioned using a single winch (a standard servo arm would likely be unsuitable here) with two drums.
One drum winds the sheet (connected to the corresponding brace) for the left side, while the other winds the tack (connected to the corresponding brace) for the right side—or vice versa, depending on the wind direction.
Rotating the winch in one direction winds up one line while unwinding the other; reversing the rotation produces the opposite effect, causing the yard to pivot around the mast.
I believe a system like this could work.
I look forward to any comments, images, or videos you might have regarding systems that have already been built.
My next post will cover the system for maneuvering and adjusting the jib.
Liked by hermank and ChrisF and
#11 61
Thanks, Ross. I thought you were going to include the photos, videos, and a brief written summary, but instead you reposted every single message exactly as they were—hahaha, that's awesome. You're really thorough.
#10 63
First off, this block and tackle system is just to keep with scale of the full sized BLUENOSE. The size of the string used for the main sheet is 1.5 mm. It is definitely oversized for the work it is supposed to do. It is rated at 95 pounds break strength. 6 strands of it would be 570 pounds.
I did find photos of the block and tackle on full sized BLUENOSE. Understanding how it works, I tried to create the same mechanical design, in miniature. Looking at the block and tackle that I rigged, it looks wrong.
I will un-do the rigging of the block and tackle and clean up the rigging of the sheet.
weight of sheeting
If my sheet was scaled up to the BLUENOSE, it would be a 36mm rope. BLUENOSE appears to be using about a 20mm rope. I have a 0.34mm braided thread I will try, to see if that will lighten the load on the block and tackle.
My counterweight is 1kg. I will start to lighten it to see what force is needed to open the the block and tackle.
When I change over to the 0.34 mm line I will check to see if it needs less load to open up the block and tackle.
A 0.75mm string is rated for 41 pounds. That is approximately the total weight of the model. 0.34 mm string will be one quarter of the 0.75 cross section, so maybe 10 pounds?? With 6 lines in the block and tackle to produce rating of 60 pounds or 1.5 times the weight of the entire vessel.
So, first job is to get the block and tackle working better.
At least it works, TEST #1: PASSED
On to test #2
#9 63
To the top, the DOUBLE BLOCK
To the bottom, the TRIPLE BLOCK on the MAIN BOOM
The red is the container full of water, the counterweight for the test
The main sheet is extended out
#8 63
Top down view of the MAIN WINCH connected by the MAIN SHEET, to the DOUBLE BLOCK that would be on the deck
#7 63
As promised, the MAIN SAIL BOOM with triple block & double block (no sails in place).
To the left vertically, is the LOWER MAIN MAST
To the right horizontally, is the MAIN BOOM
To the far right is the MAIN WINCH
To centre lower is the board supporting the counter weight for the test
#6 63
Next up will be bench test of the main boom. The excitement there will be the triple block that the main sheet runs through, the same as full sized BLUENOSE. The block is walnut wood, the sheaves are birch. The sheet travel length is about 120 cm.
#5 63
This was just the test on the bench, but it is radio controlled.
sail from the previous video is at the top of the photo
servos & switches near top,
receiver left side below it,
motors batteries, right below,
receiver battery, blue,
double drum winch, lower right
#4 63
Alessandro
I don't have the capacity to move any larger video but this is it under radio control
Little stick in the middle is the position of the leech of the foresail
Tall stick is where the main mast will be
Stick on the other side is the luff of the foresail
#3 63
Alessandro,
Firstly, I am using 5 winches. 3 winches are single drum. 2 are double drum.
The single drums are:
1) jumbo jib, lowest of the 3 jibs
2) foremast winch
3) mainmast winch
These operate in the conventional manner that you are familiar with, a single sheet to the boom. The JUMBO JIB on the Bluenose has a boom. Note that, with the winch motors all the same, the single drum design is much bigger than the double drum design. The single drum gathers up and releases much more line than the double drum, just as you would expect.
The double drums are the special use drum. The sails controlled by these 2 winches are high above the deck. The sails aloft must go AROUND another object to move from side to side, (unlike the single drum boom controlled sails lower to the deck). The JIBS winch must control 2 sails, JIB TOPSAIL & JIB AROUND the luff of the JUMBO JIB below them. The JIBS winch will carry 4 sheets
1) JIB TOPSAIL port sheet
2) JIB TOPSAIL starboard sheet
3) JIB port sheet
4) JIB starboard sheet
The good part is that the travel distance is short, so the drum can be small. Yes, in this case, one drum takes up a pair of starboard sheets while the opposite drum releases the pair of port sheets, and vice versa when the motor is reversed.
The last double drum is the one that you inspired. The STAYSAIL winch. This is the most complex of the winches. The STAYSAIL winch must GUIDE the luff of the STAYSAIL back from the FOREMAST, along the side of both FORESAILS, behind both FORESAILS and forward to the FOREMAST, on the other side from it's start point. I believe that in my build blog there is a video demostrating the movement of the STAYSAIL, being tested on the bench.
This is alot of information to absorb. Let me know which part is confusing and I will clarify further
#2 63
Alessandro
Yes, I will reproduce the earlier photos and description here, shortly.
For now, today's work
#1 74
This topic has been covered frequently, but often in a sporadic or piecemeal fashion.
We recently discussed it in a thread—titled "Sailing ship 'full-rigged ship', 'Af Chapman', now 'Dunboyne'"—that was actually unrelated to this specific subject (I’ll include a link at the end of this post).
While talking about the Af Chapman, we went off-topic and began discussing sail control systems for RC sailing models.
Ross contributed some very interesting ideas.
I’d hate to lose that information; in fact, I’d like to be able to find it easily when I need it. Buried in that other thread—along with other bits scattered here and there—it would be hard to track down.
That is why I want to use this thread to discuss "systems that regulate and control the sails of RC sailing models, ranging from simple sloops and ketches to schooners and full-rigged ships."
Contributions from anyone who has built—or is currently building—an RC sailing model would be greatly appreciated.
Since the subject isn't exactly simple, I encourage you to include sketches, photos, and videos alongside your written descriptions whenever possible.
Personal experiences are incredibly useful, but so are ideas that haven't yet been put into practice.
I’ll pick up the conversation where I left off in the aforementioned thread.
I had prepared some diagrams and was about to post them there, but I’d prefer to put them in a dedicated thread; it seems more logical and useful.
Ross, if you’re willing, could I ask you to repost the photos you shared there, along with a brief description?
https://model-boats.com/forum/169185
