brushless motor
brushless motor
cheers
Bob
brushless motor
many thanks cliff 😀
brushless motor
I use an Emax GT4020 brushless outrunner in my 49 inch perkasa. its a single motor driving a graupner 55 mm plastic prop.
The link below shows the boat running on a 4 cell lipo but I prefer using a 5 cell which makes it a bit faster than you see in the video.
I think the motor comes in two Kv ratings. Mine is the 620kv.
Using one 5000 mah 5 cell Lipo I get 40 minutes of mixed speed running including quite a lot of ripping around.
Les
brushless motor
many thanks cliff
brushless motor
I use the same motor on both my 46" Fireboat and on my slightly bigger Perkasa. it is the Turnigy AquaStar 4084-620KV, run with two 5000mAh 4 cell (14.8V) LiPo batteries in parallel, and this gives both boats a brilliant and potentially slightly overscale speed and a long run time.
Go to http://hobbyking.com/hobbyking/store/__31678__Turnigy_AquaStar_4084_620KV_Water_Cooled_Brushless_Motor.html to see it.
Both boats are single motor, single shaft, 3 blade propeller, the Fireboat has 50mm prop and the Perkasa 55mm. This motor will produce 3kW in short bursts but is relatively lightly loaded in these boats so it has power capacity to spare. The kV value is just the rpm per volt applied to the motor so a 620KV motor runs proportionally slower than say a 1600kv motor which is probably too fast for this sort of boat, and it means you can run a bigger prop. For the speed control I use see my boats on this site.
brushless motor
brushless motor
many thanks cliff
Liked by
Loading…
