newbie boat id question
Started by morph
9 replies 2 likes 0 followers Last activity: 11 years ago
The Speedline CR1700 is powered but a 1700kv outrunner brushless motor fed from Lipo 3cell battery and a Fusion Hawk 50amp ESC. additional buoyancy was fitted in case of accidents. With that set up the performance is terrific and very stable
The picture shows a Speedline CR1700 model that is supplied with a brushless motor and all the required parts except the battery and radio. I have built one and it performs exceptionally well.The kit costs £99 from Speedline models
Liked by petercbrown
Well I dunno what it is or what the full sized was BUT the hardware you have is not going to perform well with high power.
Have a look here at high performance hardware
http://www.prestwich.ndirect.co.uk/fastelectrics.htm
Its 520mmx190mm. its made from plastic, the inside is empty as its brand new. Nothing fitted as of yet. Yes the top comes off. I have a red one the same which I was given. This is a top and bottom shot of that one.
Ok now how long and how wide?
Does the top come off?
What's it made of?
Can you give us a shot of the interior
What motor is in there now?
What prop?
Haha...its like magic!! I think it was because I was on my phone at work with little internet reception
ok let's see what you need to do
select upload
find the picture you want
select open
then submit
Your pic doesn't show until your post comes on line . its shown to the side but not on your post
Haha. Cant seem to add a pic. I clicked the upload file tab, selected the pic but it doesn't appear!!
Neil
We will need rather more data than you have provided.
Pictures and dimensions would be a good starting point.
As to brushless motors the short answer is yes you can put a brushless into anything that a brushed motor could be used.
Brushless motors come in a VAST range of sizes and power outputs plus you have inrunner and outrunner options.
Liked by morph
HI all,
Im new to boats and recently was given a boat. I have it running and have purchased another hull the same from ebay today. Can anyone help me identify what I uave bought and if it would be possible to run a brushless setup in it?
Regards Neil
