Rare Comet model "Sloop Gypsy"
6 replies 4 likes 0 followers Last activity: 10 years ago
There are many mini, micro or pico motors and ECSs, also receivers on the market these days.
I've recently got into 'Plastic Magic' and am fitting out the Revell Harbour Tug kit, hull length 23cm (9 inches !!) with RC. And I'm not the first to do that with this kit. For instance look at http://www.micronradiocontrol.co.uk/
Nothing is Impossible! (I drive a Toyota!!!!!!!!!!!)
PS I didn't mean you weren't skilled enough! That was based on my own experience with a yacht hired for the day on Elba many years ago -
No Wind - No Move🤔 And then an aux. motor with a leaky cooling water hose 😲
Liked by John2
This boat is 16" it would mean a pretty small motor, speed control, which is a bit much for a small hull. I have no problem bringing my other sailboat in to my feet. it could be modelled as a sloop moving about with sails furled.
Liked by John2
It is up to you, maybe worth a try with wind power first but it would be hard fitting a small motor later.
Happy sailing.
John.
Hi Granpa!
I think he means the auxiliary motor, which most full size yachts have in case they get becalmed, or the skipper isn't skilled enough to sail into harbour 😉
Cheers 😎Doug
Liked by John2
John you mention a small motor. Are you suggesting alternate to wind power?
Liked by John2
Most modern receivers should be fine; you could use a mini servo and a small motor. You can then choose the ESC and battery based on the space you have available.
Good luck John.
Happy sailing.
John.
