Brushless for 'Sea Scout'??
Started by RNinMunich
13 replies 4 likes 0 followers Last activity: 9 years ago
Many thanks 👍👍👍
Cheers Doug 😎
Hi RN
I made a simple L bracket from 2mm aluminium with a slot cut out for the keel and the required holes for the motor.
Glued down with epoxy glue, is has work very well with the 1900kv 750 watt motor.
Liked by RNinMunich
Hi Canabus,
Got back from italy yesterday and the bits from Hobby King had already arrived, my charming spanish neighbour took them in for me 😉
Still trying to figure out how to mount the motor. if it don't work I'll send you the bill 😉😉 Thanks again for your help, cheers Doug 😎
Aha!
"Nicolaus Kanabus a kind, gentle and intelligent man." 👍👍
Got curious!
Or do you mean the Californian Eel??? 😉
Cheers Doug 😎
Yep! Cos I only got 3S at the moment😉
Maybe later I'll experiment with 4S etc, see how she goes with this setup first.
Ta for all your help 👍 😎
Hi RN
If you ordered a 30Amp ESC they only handle up to 3S.
The 60Amp and 100Amp handle up to 4S.
Liked by RNinMunich
Hi Canabus, much appreciated👍
For the first trials I'll stick with the 3S I have. Then we'll see!!
Thanks again, Cheers Doug 😎
Hi RN
The program card makes for a very easy setup and I can give you all the setting I use. the only change is from 3S to 4S and all the other settings stay the same.
Liked by RNinMunich
Sooooh!
Everything in stock at EU warehouse 😊 so just ordered motor, ESC and Progcard 😉 ~ €42. Not bad 👍 Can't wait for delivery 😎
PS No I don't have any plans, lost in the mists of time 🤔
But I don't think I need them, construction is fairly simple - standard Aerokit - and I don't plan to duplicate the boat! Thanks anyway 😎
Hi canabus, many thanks for the guidelines 👍 I'll check them out and compare with sources here in Germany.
I already have some 3S 4000mAH accus. About 300gm but I figured the boat is so light empty it could manage that, mounted fairly well aft.
Motor: I had been thinking along the lines of around 400kV, 1000kV max. So your suggestion fits 👍 Had hoped to avoid prog. cards for the ESC but Hey Ho - needs must ...!
Already have such a prop in my collection so that's good 😊
Will price up the rest and see where we go. Will post results in the Build Blog. Will be a slight delay - off to italy tomorrow for a week change of scenery! Many thanks again 😊 Cheers Doug 😎
Hi RN
You would not have the plans for the Sea Scout.
I have the Sea Hornet if you require, plus a few others.
Hi RN
From Hobbyking.
Motor propdrive V2 2830- 1000kv 370watts 3.175mm shaft(9190000328-0)3S or 4S lipo battery.
ESC 30A car(HK-30A)( XT60 connectors required), program card (HKPROG-CARD)can be used on the larger ones in the series.
Lipo battery Turnigy 1000mah 3S 30C (T1000.3s.20) 89grams 75 x 33 x 19mm or a Turnigy 1500mah 3S 25C (T1500.3S.25) 113 grams 80 x 34 x 25 mm both have XT60 connectors.
Prop about a 2 blade 30mm 1.4 pitch.
Hope this helps.
Liked by RNinMunich
Hi, as I have decided to use my refurbished, newly reversible Taycol Target in the Danish cutter restoration project I am considering going brushless for Sea Scout - 24". Weight empty 1.2kg.
Any recommendations? Like Don't Do It !! Or In / Out, kV rating???
As a newbee to BL advice would be welcome.
Ta in advance, Cheers Doug 😎
