ECS rating- confused
Started by octman
7 replies 3 likes 0 followers Last activity: 9 years ago
Hi Nick, glad to help👍
Very few if any ESCs seem to be fused! Replaceable fuses are always a better option.
By the way re 'fused unit'; 'fused' can have two meanings! One is 'joined together by a melting process'!!!! You have been warned! 😉😉
Good luck to you Chris and Dave, let us know how it goes! 😎
PS if it blows up DON'T send me the bill! 😉
So the ESC isn't a 'fused' unit then? if we put in new gear after a refurb or upgrade then we have to fuse it? I need to go to night school just to learn the basics I think....
Hi Dave, in some ways we are all 'brickies'!
I just got some great help and advice from Tasmania (!) when I needed guidance on brushless setups which are new to me. 😎
Liked by rolfman2000
Thanks Doug. You've just answered the question I was going to ask. I love this "clubby" thing. it's nice to have knowledgeable folk to help us brickies 😉 Cheers bud. Dave W
Keep it shiny side up, and rubber side down,
slowing your pace when riding through town
Yep, better safe ..... 👍
Glad to help, that's what it's all about 😉😎
Thanks for that Doug. As you say, I nearly answered my own question, but measure twice, cut once as they say.
You've almost answered your own question!
ESC: if the motor stalls, weed or plastic bag etc round the prop, the current drawn will rise to 70A. if the ESC can't handle that it will cook 😭
It's a risk that can occur any time on most boat lakes. Up to you if you want to take that risk. if you sail only in swimming pools OK no problem the Viper 20A will do 😉
Fusing: if the motor draws 11A at max efficiency it may well draw up to twice that under other conditions and depending on the prop you use. Therefore the 20A fuse is good.
Use a 'slow blow' type. The Viper 20A should be happy with that, they seem to be pretty robust. I use a Viper Marine 10 in small scale models with twin motors without problems. 15A fuse might be safer for your case. Fuse should always be well below the stall current and NEVER more than the ESC can safely handle.
To be on the safe side I would put a 15A fuse in the ESC to motor lead and a 20A fuse in the battery to ESC lead. Double this one if you have twin motors! Hope this helps. Doug 😎
Liked by Colin H and rolfman2000
I have read so much lately regarding the appropriate size of ESC for brushed motors that I am totally confused (not really totally , but nearly!). For a Graupner Speed 600 the info given with the motor is max efficiency current = 11 amps, stalled current = 70 amps, no load current = 1.8 amps. Do I need an esc rated at 70 amps or more, or a 15 or 20 amp Mtronic Viper unit be OK? Should the fuse be 15 amps, or something well above that but under 70 amps?
Questions, questions! (should have stuck to sail!)
