Hi Neil, yes, very similar. Could be regarded to as a first step before applying Eze-Kote to give it a harder, knock and almost everything else resistant surface. Hammerite then sticks to it like the proverbial to the blanket and you have a super clean 'engine compartment' dead easy to keep clean. 😊
80 quid for a brushless !!! Do you want it gold plated or what?
My Propdrive 2830 cost less than 20 knicker from Hobbyking and was delivered almost before I ordered it! Just make sure it comes from the UK or EU (still!?🤔) warehouse and not USA or Global. otherwise you might get stuck for import tax 😡
For the motor mount / shaft alignment: no one said it was easy, but Nothing's Impossible', maybe that's why I drive Toyota!!😁
back end is determined by the diameter of the prop you want to fit, which in the case of brushless motor should be roughly the same diameter as the brushless (outrunner). in my case 28mm motor and 30mm prop.
This defines how far you can lift the aft end of the shaft, leave at least 1cm between the prop tip and the hull! This reduces unwanted interaction between the vortex from the prop and the lamina flow along the hull, result; more forward thrust and better rudder effect.
(Didn't spend 30 odd years talking to shipyards for nowt😉)
If you have plan (or at least a sketch - take some measurements if you don't have one of these and make a sketch) of the keel and existing motor mount; project back from the newly determined exit point of the shaft.
Check how far forward you need to go to be able to comfortably fit the motor mount with good alignment and purchase a shaft of appropriate length. Cut a wood block to fit around the keel as the basic mount and 'fiddle' with it until your motor and mounting (e.g. the Robbe / Romarin 400 mount) aligns with the shaft line. Alignment is checked by running the motor at a fixed low speed with an ammeter showing the current it draws. Shim the motor mount up / down, and shift slowly from side to side until the current reading is a minimum. Then glue and screw everything in place quick before anything moves!
Takes almost longer to describe than to do😉
The coupling type shown in my photo is called a 'Steg' coupling here in Germany (don't know the English🤔) and available from Krick Modellbau, for various motor shaft / prop shaft diameters, here the link to their English page-
http://www.krickshop.de/?shop=krick_e
Part number for the 3.17mm (1/8") to 4.0mm version I used is 63902.
part number for the motor mount I used for my 28mm brushless is 42117.
Advantages (to me at least!) they are not as long as the traditional UJ and Cardan types, they are resilient but don't flop about like the UJ types so are much easier to fit and align. Cos they are shorter you can use 'em for mountings in confined spaces. And they don't make no noise!! 😉
One final tip (may not be so useful on hard plywood built boats!).
When I had this problem with my destroyer I sharpened the end of an 8mm alu tube (same as the shaft tube dia) and used it to bore back from the hull exit to the last bulkhead before the motor mounts. the bulkheads though were 1/4" balsa! Nice and soft man 😉
Hope this helps more than confuses, but it all worked for me!
Cheers and happy fiddling, Doug 😎
