Brushless Equivalents
Started by AndyG009
2 replies 3 likes 0 followers Last activity: 9 years ago
IC to electric conversion table
http://lmmac.net/i-c-to-electric-conversion-table/
IC to brushless ( for aircraft but its better than nothing)
https://www.cmfhobbies.com/IC-Engine-to-Electric-motor-convertion/I205.htm
Hope its some help
Liked by RNinMunich
Hi Andy
I work on the motor case around the same size as the prop diameter, the rpm and power of the old motor.
Add a few more rpm as we like to go faster.
Matching the revs from the old motor e.g. 20,000.
Kv of the brushless motor times the Lipo Battery cell number(4S= 14.8 volts) e.g. 1450kv times 14.8= 21460 rpm.
So an OS40FSR was 1.6HP @ 20,000.
Replacement 3648-1450kv = 21460rpm(no load).
Power 750 watts = 1HP and the 3648-1450kv is 1600watts.
As for brushless to brush motors you can match the rpm, but, the brushless are far more powerful than the brush motors.
As for a conversion chart it would be a big task and some of the gear is not available in all countries.
Canabus
Liked by RNinMunich and AllenA
Possibly the wrong title - but.
Has anyone produced a conversion chart:
Non-Brushless motor types to Brushless (for different manufacturers)
Glow / Diesel motors to Brushless
If not.
Does not need to be exact, but I am sure that there a many out there that have replaced or know what was originally intended to be fitted is a particular boat, and have replaced it with a brushless.
If enough people contribute - I will create a table.
