bulkheads
bulkheads
The plan is from 'green72west' who started this thread and seems to be confusing Schottel and Voith-Schneider. Either that or he wants to use two Z-Drives instead of the Voith drives. His intention is not clear. Either way he doesn't need to cut chunks out of the keel, that's nuts😲
bulkheads
First two pics show a twin Voith propeller on a tug hull (as on the plan above) and the operating principle.
3rd pic is cross section of the Z-Drive as produced by the Schottel company. it is a 360° rotating 'pod'.
Newer versions have electric motors built into the pod and don't need the mechanical Z transmission from inside the hull.
With such pods under bow and stern even bow and stern side thrusters are redundant 😊 4th pic is the Graupner version, Mk II.
https://www.graupner.com/Schottel-Drive-II-new-version-/2335/
bulkheads
This is a link to a fairly comprehensive brochure with photos of the real thing that will help in understanding the concept etc. http://www.gemimanevrasi.com/Tug_Boat_Technology/Voith%20Water%20Tractor.pdf
bulkheads
https://www.bauer-modelle.com/Voith-Schneider-Propeller-VSP-65BM-mit-Brushlessmotor
bulkheads
+ side view of the hull. there are 20 frames in the hull. how can I
install x2 graupner schottel [2335] at the bow. I will have to leave
out the keel under hull. thankyou Green. the plans are 1/50th
scale.
Liked by
Loading…
