Current Website Support
87
Contributors
11
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ1
ยฃ3
ยฃ5
ยฃ10
    Followers
    Anteo 2 Tug
    by Dick ๐Ÿ‡ฌ๐Ÿ‡ง ( Leading Seaman)
    ๐Ÿ“ฃ
    Click To
    Follow
    11 Posts 10 Replies 14 Photos 13 Likes
    Dick
    Leading Seaman
    ๐Ÿ“ Anteo 2 Tug
    Online: 1 year ago
    I didn't give it much thought when I said tap off 2x6volt in parallel. I will probably use small 4s lipo to power lights etc.
    Thanks fo pointing this out. Still a long way from installing ancillaries.
    DodgyGeezer
    Sub-Lieutenant
    ๐Ÿ“ Anteo 2 Tug
    Online: 1 hour ago
    Alternatively, pick a sensible master voltage for the boat, and use step-up/down converters to provide auxiliary voltages for other purposes? They provide efficiency in the 90% range, and power of about 5A for a couple of quid. I have been doing this to get radar dishes to rotate at precisely the speeds I want....
    1
    Haverlock
    Sub-Lieutenant
    ๐Ÿ“ Anteo 2 Tug
    Online: 1 year ago
    You can power a brushless from lead acid batteries electric is electric. Lipo batteries are often used because of their ability to provide power with a relatively low weight and can dump LOTS of amps.
    As Colin pointed out 2 6volt batteries in parallel will provide 6 volts and cannot be tapped for 12v to obtain 12v the batteries need to be in series and 6 volts can be tapped off but will only provide the energy from one of the two batteries.
    1
    "that's not a bug its just an undocumented creature." Sir Terence David John "Terry" Pratchett, OBE (28 April 1948 - 12 March 2015)
    Colin H
    Captain
    ๐Ÿ“ Anteo 2 Tug
    Online: 11 minutes ago
    Hi Dick, two 6v batteries in series wil give 12v, which you can tap off 6v if required. But not in parallel I'm afraid. Hope this helps you.
    1
    Fair winds and calm waters, COLIN.
    Dick
    Leading Seaman
    ๐Ÿ“ Anteo 2 Tug
    Online: 1 year ago
    Hi Havelock, this is my first boat build,been doing rc model aircraft for 60 years,I know all there is about brushless motors and lipos.The kit specified lead acid batteries and I am using a 2_1 mfa motor and gearbox not quite sure what esc I have got. Lot of this was guesswork.The lead acid batteries will complement whatever ballast I need.2x6v in parallel and I can tap of 12 v for lights smoke etc I think.
    Haverlock
    Sub-Lieutenant
    ๐Ÿ“ Anteo 2 Tug
    Online: 1 year ago
    if your intending to use a car ESC have a good read before you buy some of them require you to select reverse then go back to neutral before selecting reverse again to actually reverse the motor. The first reverse acts as a brake. Just to satisfy my curiosity why did you want brushed rather than brushless? There are a lot of brushless motors used in the model car sport and generally have advantages over brushed motors.
    Dick
    Leading Seaman
    ๐Ÿ“ Anteo 2 Tug
    Online: 1 year ago
    Latest update on tug.
    3
    Dick
    Leading Seaman
    ๐Ÿ“ Anteo 2 Tug
    Online: 1 year ago
    Thanks for your replies I've purchased mfa 2-1 500/550 motor.has pulley drive to drive shaft pulley
    3
    Colin H
    Captain
    ๐Ÿ“ Anteo 2 Tug
    Hi Dick, I have a few tugs and the largest at 49" uses a geared 540 running from a 12v 7ah sla battery giving a good 90mins running time. This model weighs in at 15 kilos ready to sail. I also have a caldercraft model tug Joffre. Which is about 30" long and runs using a 6v monoperm motor and gearbox. 6v 4.5ah sla battery giving about 1 hour run time. Weight is 5kilos ready to sail. Hope this helps.
    2
    Westquay
    Commander
    ๐Ÿ“ Anteo 2 Tug
    Online: 21 days ago
    Dick, as far as I know model boat/car style ESCs have a reverse function.
    I would think a geared 540 motor would be quite sufficient. People tend to overpower most model boats, especially those not required to take off like ducks on acid! Like tugs.
    2
    Show 1 More Posts
