Current Website Support
87
Contributors
11
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ1
ยฃ3
ยฃ5
ยฃ10
    Followers
    Vic Smeed's 'Waterbaby'
    by Xtal ๐Ÿ‡ฌ๐Ÿ‡ง ( Able Seaman)
    ๐Ÿ“ฃ
    Click To
    Follow
    12 Posts 11 Replies 1 Photo 11 Likes
    RNinMunich
    Fleet Admiral
    ๐Ÿ“ Vic Smeed's 'Waterbaby'
    Country: ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    Online: 5 hours ago
    Luv it ๐Ÿ˜๐Ÿ˜๐Ÿ‘
    The Bugs are on the run ๐Ÿ˜Š โ„๏ธโ„๏ธโ„๏ธ Get out and run those Sea Trials!! ๐Ÿ˜‰ Cheers Doug
    Wingcoax
    Petty Officer 2nd Class
    Country: ๐Ÿ‡ต๐Ÿ‡น Portugal
    Online: 1 day ago
    As the late Derek(Blaster)Bates said," Ex is something that has been" and "spurt is a drip under pressure"
    1
    RNinMunich
    Fleet Admiral
    Online: 5 hours ago
    Heartily agree Martin ๐Ÿ‘
    How does one become an 'expert'?
    LEARNING BY DOING!!! ๐Ÿ˜‰
    Cheers, Doug ๐Ÿ˜Ž
    As they say in this neck o the woods 'รœbung macht den Meister' - 'Practice makes the master'!
    Westquay
    Commander
    Online: 22 days ago
    You really need to be self reliant on these simpler tasks, rather than use a local "expert". There is no such thing as an expert on drilling keels! And if he suggests he is...avoid him!
    1
    onetenor
    Sub-Lieutenant
    Online: 1 year ago
    You don't need an expert. Just go for it carefully yourself. Lead is easy to drill.Re internal ballast I would remove at least part of the deck to looksee.๐Ÿ‘
    1
    Xtal
    Able Seaman
    Online: 8 months ago
    Thanks for the advice. I have changed to a smaller battery and moved it fwrd (it is R/C). I have also tried to see if there is any internal ballast but that's not easy without removing the deck.
    I think its time to drill the lead keel as suggested. I have found a local expert who says he will do the job! Will report on progress.
    Many thanks.
    John
    onetenor
    Sub-Lieutenant
    Online: 1 year ago
    As Westie said don't use a Forstner it will take out too much at once. Use the 8 mm evenly both sides. Go gently.๐Ÿ‘๐Ÿ‘ Also see if any ballast has been added inside. This was often done to reduce heeling . it defeated it's own object as reducing the freeboard still put the lee rail under when heeling. Also what batteries are you using? A change to lighter ones may help. Lipos maybe but they may reduce duration.Nimhs may be a compromise. Or the ABC types All this assuming you are using R/c.
    2
    Xtal
    Able Seaman
    Many thanks Martin.
    Westquay
    Commander
    Online: 22 days ago
    I think a Forstner cutter would be a bit vicious for lead and a bit big. Use say an 8mm drill and use a drill with a decent speed control. Start the holes by hand to ensure they go where you want. I would say start by drilling in the aft part of the keel as the boat appears to be arse down a bit. if there's any internal ballast , move it forrard.
    3
    Xtal
    Able Seaman
    Many thanks for your helpful reply. The line between the wooden hull and the lead part of the keel is very clear so knowing where to drill will not be a problem. Do you think a fostner drill bit in a hand drill (slow speed) will be best for drilling lead. its something I've not done before so any advice would be much appreciated.
    I will put some more pictures up hopefully tomorrow.
    1
    Show 2 More Posts
