Current Website Support
264
Contributors
10
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ5
ยฃ10
ยฃ15
ยฃ20
    Followers
    Your ideas on how to stabilize a flat-bottomed freighter.
    by Ron ๐Ÿ‡จ๐Ÿ‡ฆ ( Midshipman)
    ๐Ÿ“ฃ
    Click To
    Follow
    5 Posts 4 Replies 1 Photo 10 Likes
    DennisRobotham
    Petty Officer 1st Class
    ๐Ÿ“ Your ideas on how to stabilize a flat-bottomed freighter.
    Online: 22 days ago
    Hi Ron, had the same problem with my 8'-6'' HMS Fearless when I first launched it. Took out all the ballast, weighed it then replaced it with a solid steel keel on edge bolted to the underside of my boat.... cured and never any more problem since. Fast boats go past it and it sits still with the wake going along side, just like the real one. it gave the boat a stabilising keel and put all the ballast 60 mm lower than being inside the boat. Good luck with yours, interested as to how it turns out.
    3
    Dennis G.V.M.B.C
    RHBaker
    Sub-Lieutenant
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Online: 1 hour ago
    Think a bilge keel should be the first step. My next suggestion would be to add some of the ballast to a removable fin keel, bolted to the underside of the hull. This will increase the righting moment, but not the weight. This can be seen if you examine U Tube videos of cruise ships and liners. They have so much superstructure they are inherently unstable.
    Have built several freighters and always fit captive nuts into the keel or underside. These are intended for trunnion display mounts, but have always been prepared to bolt a keel on if needed. The nuts can easily be sealed when sailing.
    4
    Ron
    Midshipman
    Online: 10 hours ago
    https://www.marineinsight.com/naval-architecture/roll-stabil...
    I chose to add a bilge keel to begin with in the search of stability.
    https://www.marineinsight.com/naval-architecture/roll-stabilization-systems/amp/
    ๐Ÿ”—
    2
    Haverlock
    Sub-Lieutenant
    Online: 20 hours ago
    you could consider using some of the modern tech and fitting active stabilizers there are a lot of cheap solid state gyros and if your receiver does not have enough free inputs and outputs an arduino mini could handle the logic.
    1
    "that's not a bug its just an undocumented creature." Sir Terence David John "Terry" Pratchett, OBE (28 April 1948 - 12 March 2015)
    Ron
    Midshipman
    After adding the needed weights to bring this freighter down to a loaded ship water line, the model rocks n rolls. It needs either a keel or exterior stability fins. What is your experience? Please share with us.
