Current Website Support
87
Contributors
11
Subscribers
You are Not Registered
Β£10
Β£15
Β£25
Β£50
Β£1
Β£3
Β£5
Β£10
    Followers
    What have I got?
    by Bryan-the-pirate πŸ‡¬πŸ‡§ ( Warrant Officer)
    πŸ“£
    Click To
    Follow
    29 Posts 28 Replies 12 Photos 44 Likes
    DodgyGeezer
    Sub-Lieutenant
    πŸ“ What have I got?
    Online: 4 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    Lighter DXF file now on the web page.
    Note:
    1 - I run vintage everything here. Consequently the DXF file was generated by software from the 1980s, and may have compatibility issues with modern code. If you have problems, tell me, and I'll find a way to update it...
    http://eezebilt.tk/lightplan.html
    2 - The plan was designed for 16"-20" barges to go with the EeZeBilt Beaver. If you go much bigger you will need thicker material or some extra support in the centre to stop a long run of thin material bending. But I guess that you know that anyway...
    3 - Modern lighters - as the Spittalfields reference on the web site illustrates - typically carry freight (usually garbage) in boxes like shipping containers. Perhaps I should make up a plan for those too - but they are a fairly simple shape anyway...
    πŸ”—
    1
    Nerys
    Captain
    Online: 50 minutes ago
    😊 View Profile
    πŸ’¬ Send PM
    Hi Doug,
    Good idea to build a couple of lighters for your tug to tow, that would seem about the right size. As far as cargo/ballast is concerned, I think you could make modules simulating different cargoes to fit into the hold. The hatches were rarely covered up. Timber for instance would be stowed in the hold and then quite a high stack above the deck, but even with bulk cargoes there was usually a bit peering over the top. They were, as sailing barges, loaded down to 3" freeboard when in the river. Even if they were being towed round to the Medway from the Thames, they would still have the same 3" freeboard. There are many tales to be told of illegal activities involving lighters, -----perhaps one day!
    Nerys
    1
    Nerys
    Captain
    😊 View Profile
    πŸ’¬ Send PM
    What an interesting article about lighters and lightermen in Spitalfields Life. Thank you DodgyGeezer. Really told how it is and to a great extent was on the London River.
    One thing it didn't mention was the way lighters were the bane of a sailing barge's life in the docks. Long strings of them would be towed in and then seemingly left without mooring in roughly the place they were wanted. They would then drift around colliding with vulnerable wooden sailing barges, often causing damage. I remember Centaur having a couple of planks in her side stove in by drifting lighters.
    RNinMunich
    Fleet Admiral
    Country: πŸ‡©πŸ‡ͺ Germany
    Online: 24 seconds ago
    😊 View Profile
    πŸ’¬ Send PM
    Thanks DodgyπŸ‘ Look forward to that.
    Might try balsa and harden it with EzeKote anyway.
    Like Martin haven't worked with balsa for years, apart from the new stern for my fish cutter.
    And a similar technique worked for my destroyer all those years ago😊
    Re water ballast - I'll think about that!
    Was pondering using the load modules as ballast.
    PS I don't mind doing the cutting out myself, the table fret saw will help there.
    Besides, I don't know of any equivalent of Maker Space around her.
    2
    The Bugs are on the run 😊 ❄️❄️❄️ Get out and run those Sea Trials!! πŸ˜‰ Cheers Doug
    DodgyGeezer
    Sub-Lieutenant
    Online: 4 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    At 30" you probably want to make them out of 1/8" ply. If you just expand the plans you'll need to redraw a few slots and clearances - but that would be easy.
    They have to have a load for ballast - I found that water did a reasonable job and if it sloshed around a bit that made things even more fun to control...
    I'll just stick a dxf download on the website for anyone who wants one...
    2
    RNinMunich
    Fleet Admiral
    😊 View Profile
    πŸ’¬ Send PM
    Hi Dodgy,
    A dxf Auto-Cad file would be excellentπŸ‘
    I can import that into my Corel Designer Tech Suite and scale to suit.
    1
    RNinMunich
    Fleet Admiral
    😊 View Profile
    πŸ’¬ Send PM
    Thanks NerysπŸ‘
    My tug is about 1/36, so a 90footer would give a model lighter about 30" (76cm).
    So would look pretty good behind a 56cm tugπŸ˜‰
    Now to start fantasising about the load module possibilities😁
    DodgyGeezer
    Sub-Lieutenant
    Online: 4 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    This is how they work nowadays - http://spitalfieldslife.com/2011/09/28/among-the-lightermen/
    πŸ”—
    1
    Nerys
    Captain
    😊 View Profile
    πŸ’¬ Send PM
    Hi Doug,
    A Thames lighter varied in size , there were some quite small, only about 70ft but the majority were about 90ft long with about 24 ft beam. The proportions of the Eezebilt plan looks about right to me.
    Nerys
    1
    DodgyGeezer
    Sub-Lieutenant
    Online: 4 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    "That is a good model of a Thames lighter and I imagine the boat that started this post was very much like it before the wheelhouse was put on.
    Is it available as a kit, or just the plan?"
    It's a standard EeZeBilt 50+ model. That means it's been designed to be cut out of balsa sheet and assembled in the simple EeZeBilt fashion, and the plan has been put out for free download. It's capable of being made at any size or any material, but making it at 16" just nicely uses a single 1m sheet of 1/8"balsa. The idea was to produce simple, quick, cheap model barges so that the tug boys had no excuse not to be pulling a whole string of them.
    If you want it as a kit, I can send you a .dxf file and you can get someone with a CNC machine to do the cutting for you. Do you have a MakerSpace anywhere near you?
    2
    Show 19 More Posts
