Current Website Support
71
Contributors
6
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ1
ยฃ3
ยฃ5
ยฃ10
    Followers
    Turnigy 120amp Watercooled ESC
    by HoweGY177 ๐Ÿ‡ฌ๐Ÿ‡ง ( Petty Officer 1st Class)
    ๐Ÿ“ฃ
    Click To
    Follow
    18 Posts 17 Replies 0 Photos 2 Likes
    Martin555
    Vice Admiral
    ๐Ÿ“ Turnigy 120amp Watercooled ESC
    Online: 36 minutes ago
    Hi,
    I don't know if this will help.
    https://youtu.be/2HIVAl8TBT0
    ๐Ÿ”—
    โ–ถ๏ธ
    1
    HoweGY177
    Online: 25 days ago
    Tried and checked , battery fully charged, rudders working, switches checked but still a continuous beeping. Even changed transmitter and receiver but no better. Will have another word with HobbyKing tomorrow. Thanks for all your suggestions. ๐Ÿ‘
    KenThompson
    Sub-Lieutenant
    Online: 1 day ago
    Is it telling you that the battery level is low?
    check or re charge.
    Or it could be that the timer on the tx has been set, and its run down, or reached its set level..toggle switch top left on tx?.Could have been switched on by accident.
    May the wind always be always where you want it .
    G6SWJ
    Online: 4 hours ago
    Don't give up just yet - it's always difficult typing suggestions when instinctively if the kit was infront of you you would just do things!
    Do you have a servo tester?
    Do a visual check of the 3 pin rc plug on the esc - pins look ok / seated correctly/ haven't pushed themselves out of the back of the plastic plug?
    Just to confirm are you using the throttle channel on the receiver?
    What is the model number of the Spektrum receiver?
    Jonathan
    HoweGY177
    Online: 25 days ago
    No joy but thanks for suggestion.
    Vic
    HoweGY177
    Online: 25 days ago
    I had the same trouble with the one that is now working, I just kept playing around trying every combo that included the programme card and the motor burst into life but buggered if I know the sequence that proved successful. All i can recall is the bleeping changed and hey presto. Tried moving sticks and re-setting max setting. but no joy with this fellow.
    KenThompson
    Sub-Lieutenant
    Online: 1 day ago
    Hi ,, I think it is telling you no signal for a while, just move one of the sticks, and it should stop bleeping.
    G6SWJ
    Online: 4 hours ago
    The constant beeping suggests the esc is not seeing a signal from the receiver or not one that it sees as โ€œfullโ€ throttle.
    How did you program the esc that is working - via the radio tx/Rx or the programming card?
    If via the radio use the same Rx slot/channel and check that this channel has not been reversed nor has the output been restricted by the digital trims(end point adjustment)
    HoweGY177
    Online: 25 days ago
    Spectrum 7 transmitter with spectrum 5 Chanel receiver. I set them up for programming independent of each other, no cross interference.
    G6SWJ
    Online: 4 hours ago
    What radio /receiver are you using?
    How are the 2 ESC's connected to the receiver?
    When you try to program the misbehaving ESC how is it connected to the receiver? Is the other ESC disconnected?
    Jonathan
    Show 8 More Posts
