Rudder position
HI John
Nice sleek looking model. Can't see any further aids to straight running but the prop is almost in the middle of the boat so the turning balance will be well out of optimum and even with a large rudder the forces on the rear of the boat will tend to neutralise the effects of the rudder. Had a similar problem with my Aerokits Solent Lifeboat. it would start to turn then suddenly snap back to straight - all due to the large keel fitted. I solved this by reversing one prop on the turn, but this is no use to you.
I believe you may have to move the prop towards the rear, but initially I would just remove the back keel, fit a rudder and see how it goes. if it works ok for you fine, if not you will have to move the prop.
Good luck - please keep us posted
