Country: πΊπΈ United States
Online: 6 days ago
π View Profile
π¬ Send PM
Thank You Sir. I agree with your suggestion. I also recognize the plan that you included, as i have been following your progress. You did a fine job on the Fireboat. Thanks.
Country: π¬π§ United Kingdom
Online: 13 hours ago
π View Profile
π¬ Send PM
My approach would be to construct a frame to stabilise the fibreglass hull and avoid any twisting, this is essential to enable accurate measurements to be made with regards to the position of the motors and associated shaft tubes. Take a look at the attached picture and scale the positions to your hull I hope this helps
Online: 6 days ago
π View Profile
π¬ Send PM
I have a 41" fiberglass hull with a 12" beam. I would like to install a twin shaft electric drive system-counter rotating props. I'm a novice at doing this. Where can i find info on the installation of drive system? i can build it. I would like to configure the components correct the first time. The deck, and electronics are the easy part. I'm concerned about the shafts, struts, bearings, stuffing boxes, rudder, and motors. Thanks
π Like
1
π¬ Reply
π 1 Views
ποΈ Basket
You can do a one-off donation anytime
Β£10
Β£15
Β£25
Β£50
New Drive System
Trending Topics
Members Online
Boat Build Help
WellsBoi
15 minutes ago
π€
Boat Build Help
Martin555
34 minutes ago
π€
Blog
Re: Preparing the railings
Martin555
1 hour ago
π€
Blog
Re: Constructing the Cabin
Martin555
1 hour ago
π€
Flashing LEDs
Ianh
5 hours ago
π€
Harbour
Re: Next on the building board.
Ron
10 hours ago
π€
R.N.Dark Class
tony29h
13 hours ago
π€
Cruise Ships
hammer
14 hours ago
π€
Blog
Re: HARTLEY FLARELINE, SOMETHING COMPLETELY DIFFERENT
