"your welcome to take the point away"
No need to take the hump Brian.
Just think a little more about what it is that you are trying to tell us and show us.
Remember; a picture tells a thousand words😉
Hi Brian,
Very pleased to see that you decided to go for an 8mm tube👍
That leaves you some 'meat' to play with for bushes/bearings😊
If you use a 6mm running tube with a 4mm drive shaft, as some have advocated, that only leaves you 1mm to play with for outer tube and bearings. Not a lot☹️ Resulting in a comparatively flimsy arrangement that I would only want to use for very short shafts at low revs. If at all.
Personally I would regard 3mm as the absolute max diameter of a shaft in a 6mm outer, and then only for short e.g. >/=6" or so shafts.
That's my humble twopenn'orth anyway.
Wonder whose shafts / bearings will last longest 😁
Happy building👍
Stay safe🤞
Hi Brian,
Happy building👍
Stay safe🤞
I heartily agree Martin👍
Such text posts are pointless (apart from ranking points🙄) without the associated pics and some explanation of HOW!
Brian, some set-ups use a small washer, then a nut, last a threaded prop. Other set-up is the washer, then a “Dog”, a prop then a lock nut.
Hope these images help.
Ron
[{"id":"160683477734","name":"160683477734.jpeg","caption":"","url":"https:\/\/model-boats.com\/media\/160683477734\/l","thumbUrl":"https:\/\/model-boats.com\/media\/160683477734\/s","isImage":true,"ext":"jpeg"},{"id":"1534813826","name":"1534813826.gif","caption":"","url":"https:\/\/model-boats.com\/media\/1534813826\/l","thumbUrl":"https:\/\/model-boats.com\/media\/1534813826\/s","isImage":true,"ext":"gif"},{"id":"160683491786","name":"160683491786.jpeg","caption":"","url":"https:\/\/model-boats.com\/media\/160683491786\/l","thumbUrl":"https:\/\/model-boats.com\/media\/160683491786\/s","isImage":true,"ext":"jpeg"}]
was only going off what it says in the plans and instructions the plans leave you to do a lot of guessing about depths of cut etc etc will not buy anymore of these plans
brian
brian
only one photo came up will try again tomorrow
brian
brian
first boat waiting for some gear then can put skins on
photos not very good
brian
[{"id":"160668434663","name":"160668434663.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/160668434663\/l","thumbUrl":"https:\/\/model-boats.com\/media\/160668434663\/s","isImage":true,"ext":"jpg"},{"id":"160668438629","name":"160668438629.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/160668438629\/l","thumbUrl":"https:\/\/model-boats.com\/media\/160668438629\/s","isImage":true,"ext":"jpg"}]
