Current Website Support
86
Contributors
27
Subscribers
You are Not Registered
Subscribe for your gold medal ๐Ÿ…
Until Cancelled
ยฃ1
ยฃ2
ยฃ3
ยฃ5
Donate for your silver medal ๐Ÿ…
12 Months
ยฃ10
ยฃ15
ยฃ50
    Login to Remove Ads
    Followers
    Building Katie
    by Muskrat ๐Ÿ‡ฌ๐Ÿ‡ง ( Warrant Officer)
    ๐Ÿ“ฃ
    Click To
    Follow
    3 Posts 2 Replies 10 Photos 5 Likes
    Muskrat
    Warrant Officer
    ๐Ÿ“ Building Katie
    Online: 3 hours ago
    Hi Dave, Thanks for your pictures that really helps and with the links i got from Graham93 between you both that sorts out were the confusion was coming from.
    Cheers Jon.
    1
    j a Easter.
    Lieutenant
    ๐Ÿ“ Building Katie
    Online: 14 hours ago
    Hi Jon
    This is fairly typical for the period and type of vessel.
    Basically two bands round the mast support a small shaft that can rotate in bearings in each band. The shaft has a flat spot on each side in the middle with a hole. The mast has a slotted shaft attached to the boom that also has a hole through each slot. This fits over the shaft attached to the mast and a pin or bolt is used to attach all together.
    Some vessels had a rotating boom to reef the main sail but I can't see this detail on your drawing.
    The system will work well so you should have no problem in it's use.
    The gaff is a boom with two side cheeks attached and shaped. There is a support on the mast to hold the gaff and Parallel beads are attached across the open end to hold to the mast
    https://images.app.goo.gl/FX87cvWuEVsaH4Mw9
    Not that difficult to make and will look correct on Katie.
    Some pics of my Cariad rigging to give you a bit more detail. I used brass but wood is more typical.
    Have fun
    ๐Ÿ”—
    3
    Muskrat
    Warrant Officer
    ๐Ÿ“ Building Katie
    Online: 3 hours ago
    Hi All as the picture shows on the photo and my build blog can anyone help with the Boom Gooseneck type on my plans should use this type or should i use a more modern type, i would like to keep Katie original but unsure about using this type, It Does say in say on the plans and description that Katie is Gaff rigged boat and does not show the making of that on the plan slightly confused, What do you think ?
    1
    j a Easter.
