Teak decks
If the planking supplied is to scale then that would give a full size plank width of 3 x 60 = 180mm or just over 7". Build being at a scale of 1:60.
The planks may be a bit over scale but less width may not be readily available and would be difficult to handle and glue in place?
Paul, for your build, depending on the scale your planks may be wider. What scale are you looking at/building to?
