motor for vosper mtb 1/35 scale
Started by bladeraider21
4 replies 3 likes Last activity: 4 years ago
This is my 27" all wood perkasa running on a single screw.. The motor is a 2822 1250kv outrunner with a 60a esc. The prop im using is a x 40
Built a similar vessel. my RAF RTTL 2762E.
The blog is in the library. Also built a triple screw HMS BRAVE BORDERER.
That blog is also in the library and is a litany of trials and tribulations.
They might give some background and guidance.
Liked by Tica
1/35 scale in wood may cause some challenges with the weight, but old school setup with one 385/400 type with a light weight 2S LiPo and a cheap 10-20Amp ESP striped down may be the solution, personally I would opt. for a Brushless setup with 2S Lipo, any ways it require that you have a charger that can handle LiPo´s. BrushLess can also be slow but the weight of them are minimal compeer to a brushed alternative.
It would be better if you gave the size of the boat eg (length)
Is it single or twin prop?
who's plan are you using?
Are you going for brushed or brushless motor
Then someone may be able to help
have a look at my last MTB it gives the sort of information you need
https://model-boats.com/harbour/108351
Liked by stevedownunder
hello ,I'm new to the site and would apricate some advice.I am building a wood remote control model of a vosper mtb .can anyone please advise me on which size motors and remote control unit to use.i would like it travel at a moderate speed not to fast.thankyou.
Liked by jayden
