Current Website Support
88
Contributors
28
Subscribers
You are Not Registered
Subscribe for your gold medal ๐Ÿ…
Until Cancelled
ยฃ1
ยฃ2
ยฃ3
ยฃ5
Donate for your silver medal ๐Ÿ…
12 Months
ยฃ10
ยฃ15
ยฃ50
    Login to Remove Ads
    Followers
    Removing Prop
    by garyp ๐Ÿ‡ฌ๐Ÿ‡ง ( Leading Seaman)
    ๐Ÿ“ฃ
    Click To
    Follow
    5 Posts 4 Replies 0 Photos 1 Like
    roycv
    Warrant Officer
    ๐Ÿ“ Removing Prop
    Online: 7 seconds ago
    HMMMM not sure about that Len, however some penetrating oil and then trying turning the other way might loosen it all up.
    I assume you cannot remove the prop tube? They often respond well to a big hammer!
    Len
    Leading Seaman
    ๐Ÿ“ Removing Prop
    Online: 43 minutes ago
    It may be possible that the lock nut may a left hand thread so you can try to turn it as if you were going to tighten it to see if that helps.
    roycv
    Warrant Officer
    ๐Ÿ“ Removing Prop
    I would try some heat from a soldering iron that can usually unglue loctite.
    Lieutenant
    ๐Ÿ“ Removing Prop
    Online: 5 hours ago
    Hi garyp
    If you have a threaded coupling at the motor end also with a lock nut, you should be able to hold this in some pliers and use a thin spanner or pliers to undo the lock nut and prop. Try tightening the nut a little first to break the seal. You should then be able to grip the prop in some thick cloth and take it off.
    That is the easy solution.
    If this doesn't work then, remove the shaft from the boat, you will have to disconnect the motor fittings and possibly also remove the rudder.
    Once the shaft is out you can use a vise with paper wrapped round the shaft to hold it and then remove the locknut and prop as above.
    Hopefully the first method will work.
    If you are not intending to use the prop again you could use more destructive holding methods.
    Good luck and please let us know the end result
    1
    garyp
    Leading Seaman
    ๐Ÿ“ Removing Prop
    Online: 10 days ago
    The person who had my boat before me had the propellor fitted so it cannot be removed..The only problem is I want to remove it!.How to I remove the prop without damaging the boat, drive shaft etc.. It has a locking nut and has obviously been loktited on to the hilt. Its a [plastic two bladed affair so extremely hold to handle...Please can anyone offer any advice.
    Gary Pressman
