Current Website Support
88
Contributors
28
Subscribers
You are Not Registered
Subscribe for your gold medal ๐Ÿ…
Until Cancelled
ยฃ1
ยฃ2
ยฃ3
ยฃ5
Donate for your silver medal ๐Ÿ…
12 Months
ยฃ10
ยฃ15
ยฃ50
    Login to Remove Ads
    Followers
    Bilge pump ?
    by steve mull ๐Ÿ‡ฌ๐Ÿ‡ง ( Leading Seaman)
    ๐Ÿ“ฃ
    Click To
    Follow
    6 Posts 5 Replies 0 Photos 8 Likes
    steve mull
    Leading Seaman
    ๐Ÿ“ Bilge pump ?
    Online: 6 days ago
    I would like to add to my question about Bilge pumps. that in my RAF style launch, the water ingress problem has stopped
    One, as i filled the mainshaft tube with vaselaine, but probably more so, that i sloshed clear varnish around the inside of the hull in all compartments, let it dry, and did the same again,
    I now as of today, have NO water ingress at all,
    steve
    1
    river rat
    Petty Officer 1st Class
    ๐Ÿ“ Bilge pump ?
    Online: 2 hours ago
    I used a hydro switch and a 3v-6v pump at 3v. Mounted the switch 1/4" above the pump pickup. It comes on when the switch gets under water and goes off when the water is out. So far has worked perfectly.
    1
    steve mull
    Leading Seaman
    ๐Ÿ“ Bilge pump ?
    Online: 6 days ago
    Thanks for the replies,
    I did think about a windscreen washer pump, and am running a 3s lipo,. so 12v on tap,but overnight in my dreams (weird ones) i used a large syringe when the boat was back in port
    Steve
    pressonreguardless
    Lieutenant Commander
    ๐Ÿ“ Bilge pump ?
    Online: 1 hour ago
    Hi Steve,
    I did install a bilge pump in my Typhoon.
    It is from Ram Electronic Devices, they are located in the US.
    http://www.ramrcandramtrack.com/
    The bilge pump is Ram 45 listed under fail safe devices
    Trev
    ๐Ÿ”—
    1
    GregHiltz
    Leading Seaman
    ๐Ÿ“ Bilge pump ?
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Online: 4 hours ago
    Hi, Over the years, I have used numerous setups for bilge pumps and water ingress alarms/switches for members in our club, and ultimately to sell.
    I had a friend years ago who was quite adept at devising speciality circuits. He made a water sensor alarm which was only size of a large Postage Stamp. He made approx. 20 units before he died, and I still have one left.
    I have another modeli g friend who has found a similar unit on- line which can be wired to a small pump and alarm. I still do have a couple Robbe water pumps in stock. And it is also possible to incorporate a windscreen washer pump into the bilge to suck out the evil water.
    2
    steve mull
    Leading Seaman
    ๐Ÿ“ Bilge pump ?
    Online: 6 days ago
    Hi all
    Does any one fit a bilge pump, in their models?, as i seem to be able to get a nice amount of water, but no fish after a 15min blast round the lake, i say nice amount of water, but more like 1/2 a coffee cup worth, but its a pig to get out, so i might have to fit a drain hole, as in dummy exhausts to let it out
    3
