46" Fire Boat Leaking Keel
The general method of Tall Paul is very good. I have certainly dried out the wood thoroughly(in the Oz sunshine) {ON A FUEL SOAKED MODEL where the paint gave away afeter 10 years I even soaked the soaked area only with metho to absorb the oil and SET ALIGHT which burns the metho and put out after 1 to 2 seconds without model / wood burns AT ALL, us modellers are dions of adventure and Imagination for our hobby}. Anyway, I sand down generally ( total bare wood is not absolute just get most paint off as some stays in the grain holes. I then paint or dab in aquadhere (Poly Vinyl Acetate PVA) white wood glue( forget about telling me it is water soluble , yes it does eventually let go when soaked for a week but not when sealed as in a model ) Anyway try to glue the coming apart ply and clamp at least two days wherever you can to glue damaged bits.THEN BEFORE proceeding with the best tips from Paul mix your fibreglass resin with an EXTRA/double extra amount of drops or mls of the hardener only and thin it 30 to 40 percent with acetone thinners and as a paint runny, very runny paint it and watch it SOAK into the wood/paint model area forever and PRESERVE your model from, rot, water, oil, age deterioration, softening of wood and nasties from anywhere. Then when it is / has gone 'off' rememberadd double drops the extra hardener to 'fix' the fibreglass resin but it takes a lot slower to 'fix/set' the resin mix as it is thinned to soak,(actually you are just mixing a double amount of hardener in thinned resin and takes a while more to'fix/set') all experience and do tests on spare wood till you get the technique with longer to set/fix then follow Pauls best advice with the same resin seal/repair or cloth resin/ seal repair or addition of ply braces/ resin repair, whatever is your fancy, whatever . All the best Lyle.
