Hi Tony, thanks for your interest, the warship in background is the HMAS Sydney (2) a 1/72 scale RC model scratch built. It is built in 2 halves which can be easily bolted together pondside before ballast is added. This makes it easy to deal with a working 2.4metre long model.
It is pictured in the August 2022 Model boats mag. As I get older my models are carefully designed for practicality in transport and operation. The entire superstructure is attached to large deck access panels which are held on with magnets. The launching procedure is to first remove all superstructure, bolt the 2 halves together, carry the hull to the pondside and place on stand, fit ballast, add superstucture, then lift into water with slings under hull. A youtube clip is available if you google HMAS Sydney RC on youtube, piratefleet channel.
โฉโฉ
No likes yet
for every like received
