    battery
    7 Posts ยท 5 Followers ยท 0 Photos ยท 16 Likes
    Began 9 months ago by
    Petty Officer 2nd Class
    Italy
    Latest Post 9 months ago by
    Admiral
    Italy
    AlessandroSPQR
    Admiral
    ๐Ÿ‡ฎ๐Ÿ‡น Italy
    ๐Ÿ“ battery
    12 Views ยท 1 Like
    Country: ๐Ÿ‡ฎ๐Ÿ‡น Italy
    Online: 2 hours ago
    Ciao Fulvio ti ho scritto in privato, controlla i messaggi PM.
    Ho risposto alle domande sulle curve di scarica, sulle batterie e sui circuiti separati.
    Hi Fulvio I wrote you privately, check the PM messages.
    I answered the questions about discharge curves, batteries and separate circuits.
    fulmic
    ๐Ÿ‡ฎ๐Ÿ‡น Italy
    ๐Ÿ“ battery
    22 Views ยท 1 Like
    Online: 6 months ago
    BobbyN thanks for the clarifications i will check your way.
    LewZ
    Rear Admiral
    ๐Ÿ‡บ๐Ÿ‡ธ United States
    ๐Ÿ“ battery
    27 Views ยท 3 Likes
    Online: 6 days ago
    I would not connect two voltage sources (i.e.. batteries) to the same receiver. Could be hazardous to the receiver's life.
    Lew Zee (LewsModelBoats.org)
    BobbyN
    Chief Petty Officer 2nd Class
    ๐Ÿ‡ฆ๐Ÿ‡บ Australia
    ๐Ÿ“ battery
    42 Views ยท 3 Likes
    Country: ๐Ÿ‡ฆ๐Ÿ‡บ Australia
    Online: 1 day ago
    Hi Fulvio
    The first thing you should do is check the voltage on your battery. You said the RX voltage was coming up as low. The two likely causes for this are the battery itself is faulty or the BEC component of your speed controller is faulty. So the first check is to put a multimeter across the battery and if it reads less than 6V you need to replace the battery. If the battery is OK then unplug the lead from your speed controller and carefully check the voltage between the red and black lead this should read above 4V (niminally 5V) depending on your ESC and radio. If this reads OK then you need to look further.
    Because you said sometimes you get the low voltage warning this may be just a loose connection so when the boat is running on the bench just slightly wiggle the connections to see if you get a reaction. If all else fails you could try a new receiver, in my experience this is unlikely to be the problem but I have seen it happen before.
    Hope the above is of some help.
    AlessandroSPQR
    Admiral
    ๐Ÿ‡ฎ๐Ÿ‡น Italy
    ๐Ÿ“ battery
    35 Views ยท 3 Likes
    Online: 2 hours ago
    Hi Fulvio, I'm replying to your private message, but if you want I can duplicate the reply here too.
    It may be of interest to others.
    cjanik001
    Chief Petty Officer 1st Class
    ๐Ÿ“ battery
    50 Views ยท 3 Likes
    Online: 17 hours ago
    Good morning Fulmic,
    If the 6v lead acid battery is giving a low battery signal, then the additional 6v battery is probably not going to solve the issue.
    Check your receiver specifications for voltage input range!
    You may need to power the receiver with a separate higher voltage battery, and wire the motor independent with the 6v lead acid.
    Good luck
    fulmic
    ๐Ÿ‡ฎ๐Ÿ‡น Italy
    ๐Ÿ“ battery
    57 Views ยท 2 Likes
    Good Morning, I have one question regarding the battery power for a ship.
    I have an Elke Graupner boat and I use a battery Pb 6V to run the ESC and the RX in the same time. Same of the time the Tx show me the message "low voltage at the Rx".
    In this case can I add a battery NiMh 6V on the channel 6 of the RX just for power of the RX and keep in the same time the main battery for the ESC on the channel 1? thanks Fulvio
