    Servos
    4 Posts ยท 2 Followers ยท 0 Photos ยท 20 Likes
    Began 1 year ago by
    Admiral
    Latest Post 12 months ago by
    Admiral
    roycv
    Admiral
    ๐Ÿ“ Servos
    23 Views ยท 2 Likes
    Online: 2 hours ago
    Hi Mike, There is nothing much to add to what I said. However the connector is not even an old type RC connector.
    I have been using RC since the 1960s and familiar with all of the connectors in use then and later.
    This 5 gram servo is a Hitec HS 50, I have others with a standard RC plug.
    Mike Stoney
    Rear Admiral
    ๐Ÿ‡จ๐Ÿ‡ญ Switzerland
    ๐Ÿ“ Servos
    22 Views ยท 1 Like
    Country: ๐Ÿ‡จ๐Ÿ‡ญ Switzerland
    Online: 3 days ago
    Hi Roy,
    Would you have some photos?
    These servos are certainly original ones from the 1970s . . .
    ๐Ÿค”
    roycv
    Admiral
    ๐Ÿ“ Servos
    25 Views ยท 3 Likes
    Online: 2 hours ago
    Hi all I am looking for info on other applications of servos.
    I bought some servos in a box. One of them is a 5 gram servo with 5 wires coming out to an in-line plug.
    From one end the colours are, blue, red, white, black, mauve.
    It appears to be glued together with no assembly screws, so unable to investigate innards.
    Just wondering if there are no electronics inside and perhaps meant for Arduino or the like.
    I would like to use it but seek advice first.
    roycv
    Admiral
    ๐Ÿ“ Servos
    62 Views ยท 14 Likes
    Online: 2 hours ago
    I, like many others, use standard size servos. But they are sometimes too large for the job.
    I also use the 9 gram servos, generally with just 0.5 kgrams per cm torque available. This is OK as a rudder servo for about 10 Watts motor power.
    I have even smaller ones at 5 grams!
    Recently, while trying to find a suitable servo to tuck away for the rudder in a small yacht, I came across 17 gram servos and bought 3 of them.
    They were just the size I wanted with a 1.8 kgrm per cm torque. Worked out at about ยฃ4 each, including delivery.
    I have tested them with old RC (27Mhtz) and they perform well, no chatter when running with motor and esc. (some of my 9 gram servos are very bad)
    Dimensions;- 28mm across X 13mm wide and 30mm high + lugs which stick out a bit further.
