    Sealing Joints
    4 Posts ยท 4 Followers ยท 0 Photos ยท 11 Likes
    Began 12 months ago by
    Petty Officer 1st Class
    Latest Post 12 months ago by
    Spence
    ๐Ÿ“ Sealing Joints
    Online: 11 months ago
    Thanks Guys, Spence.
    IanL1
    Midshipman
    ๐Ÿ‡ณ๐Ÿ‡ฟ New Zealand
    ๐Ÿ“ Sealing Joints
    37 Views ยท 5 Likes
    Country: ๐Ÿ‡ณ๐Ÿ‡ฟ New Zealand
    Online: 5 hours ago
    I used epoxy from west system to build by Venice water taxi as it is so verstile. I used the resin mixed with mahogany sanding dust to make the glue to join the planks (the boat is made from mahogany so it matches) You can buy micro balloons to add to made a filler or glue. The epoxy is the best waterproofing you will buy. If the wood has other coatings on it they will need to be removed before using epoxy. Hope this helps. Cheers Ian ๐Ÿ‘
    Ian Langley
    algon
    Chief Petty Officer 2nd Class
    ๐Ÿ‡บ๐Ÿ‡ธ United States
    ๐Ÿ“ Sealing Joints
    63 Views ยท 3 Likes
    Online: 4 days ago
    Just make sure it is a waterproof PVA.
    Spence
    ๐Ÿ“ Sealing Joints
    65 Views ยท 3 Likes
    What do the forum use to seal joints in wooden boats? I have been using JB Weld but it's quite expensive and you don't get much. I always use woodscrews when fitting joints in tongue and groove floorboarding that I use, (I over ordered when repairing a floor so I thought I'd try and make some boats with the excess). I've read on the forum that PVA glue is used quite a lot and reasonably priced. Cheers Spence.
