Strange Problem with Flysky I6
In our Association we occasionally have had similiar problems and we have found that in a majority of cases this is due to faulty connections. If you put the boat on the bench and run it then wiggle each of the connections in turn you may be lucky enough to isolate the problem.
You cannot delete one of the model settings as there are 20 "channels" for individual models. My radio now effectively has only 19.
Just wanted to share a problem I had with one of my Flysky I 6 radios on Saturday. About half an hour into our weekly sail the radio gave a low receiver battery warning so I retrieved the boat. This boat is only 4 years old and had been very reliable. After a great deal of testing back at home I found the speed controller had failed and the servo. Initially I did not believe that two components could fail togther but they sertainly had. But more strange is that the model setting, one of the 20 the radio has, continued to give a low receiver warning even after I had changed out the faulty parts. I have tested some of the other models I have on that radio and they work fine. I then moved to a new model setting and everything worked fine. I tested with a number of receivers and they gave the low receiver battery error on the "faulty" model channel but were fine on the new channel. I want to avoid using the reset as this will mean I have to setup all my models so I have not reset the radio.
I guess my underlying concern is how reliable the radio will be. Has anyone else had a similiar issue with the Flysky I6?
Liked by
Loading…
