Dead short
Followers (3)
- Stephen TBronze
Dead short
If it is a brushed motor and speed control, then the leads to the speed control are positive and negative. If they are reversed, you will probably fry the speed control. The leads from the speed control to the motor are reversible. Swapping them will only cause the motor to run in the opposite direction.
IF you reverse the positive and negative feeds to the speed control, ones that should be connected to the battery, hopefully with a fuse in line on the positive lead, with the leads from the speed control that should be hooked to the motor than you may show a dead short, or again, fry the speed control. Not know which ESC you have, I have found that some Chinese units are very lacking in directions and some even come with improper color coding for the wire leads.
Hope this helps.
Dead short
You could attach some photos in which you can clearly see both the wiring and the individual components (motor, esc, battery).
I ask you this to try to verify: how the wiring is made, the state of the individual components (if they seem damaged) and their characteristics.
If the battery voltage is 12 volts and the engine voltage is 12 volts, if the wiring is correct I can assume that the ESC is less volts (the most common ones reach 8.4 volts).
Also for this reason I would like to see a photo.
Dead short
Liked by
Loading…
