Another RAF Crash Tender restoration
HI Emma
Give the hull and all other areas a good sanding to get it smooth, if its fairly smooth already you can use scouring pads to rough the area.
Spray with Grey acrylic primer, just a light coat, this will highlight any highs and lows in the finished area, sand with 1200 wet and dry used wet with a few drops of washing up liquid in it.
Spray again lightly and sand back.
You should now have a nice smooth hull to apply your top coats of colour. I assume Black with Red lower hull.
Spray the red first overlapping onto the black area, mask the red and a light spray of clear over the masking tape line red to black, to stop any creep
under the tape edge. Spray the black, final coat peel the masking away while the paint is still tacky stopping any splitting as the tape pulls away.
Paint supplies.
I use Simonize acrylics, of ebay, £3.00 per tin, also available from Eurocarparts. Halfords is another supplier but is twice the price. if you have a company near you that supply the car refinishing trade you can get your supplies from them.
As a guide this should get you started, any probe or worries let me know.
Etherow Model Boat Club
