New radio gear
Been testing the Storm S603 receiver with my Spektrum ds6I & ds6 transmitters. it does work with both transmitters.
It does have a slightly different layout of the connections in as much that the bind connections are at 90A to the main ones and are independent of the servo & battery connections. There are no instructions with it. Follow the transmitter instructions. Importantly as I frustratingly found out. Once bound together, remove The bind plug immediately or if you switch off model or transmitter, then on again, all binding is lost. And the process needs repeating. Another tip, if a bind fails kill all power to receiver to reset.
Hope this helps anyone. it's my first time trying these and I have 2 more on order. Time will tell.
