Power for a Taycol Motor
Welcome to the site.
... I have a Double Special which is similar to your motor but is reversible by means of changing one wire between two contacts. I have never used the motor in a radio control model and do not know if it is possible to use a standard speed controller. I suspect you would need some form of current rather than voltage control to avoid the motor from overheating at low voltage. ...
Use a standard speed controlled with a rectifier, or twin diodes.
http://taycol.hobby-site.com/install.html refers...
