changing connectors on ESC or motor
I suspect the warning came with pre wired ESCs, where changing the connectors can sometimes invalidate the Guarantee.
If your brushless connectors are the wrong size or type you may have no option but the cut off and fit the correct ones, unless you can change the connectors on the ESC. if you don't want to alter either then you could make a very short conversion lead with the relevant connectors at each end.The length should be kept as short as possible to avoid the chance of introducing any timing issues.
Replacing connectors should not cause any problem if you cut and replace very close to the original connectors.
