Rx POWER
Traditionally, when powering a Rx from more than one source, such as using a BEC circuit and a separate Rx supply battery, the positive power feed from the ESC is disconnected. This avoids the double power feed.
I am embarking on a triple hand screw model with 3 x ESCs so each screw can then be controlled individually from the Rx.
In this situation, where all the Rx power will come from ESCs running off the same main battery (using the BECC), with no separate Rx battery supply, is it necessary to cut all the positive ESC supply leads except 1?
Appreciate any advice.
Thanks
Rowen
