Current Website Support
87
Contributors
11
Subscribers
You are Not Registered
Β£10
Β£15
Β£25
Β£50
Β£1
Β£3
Β£5
Β£10
    Followers
    What is the optimum prop shaft angle?
    by Ron πŸ‡¨πŸ‡¦ ( Lieutenant Commander)
    πŸ“£
    Click To
    Follow
    6 Posts 5 Replies 11 Photos 8 Likes
    boaty
    Chief Petty Officer 2nd Class
    πŸ“ What is the optimum prop shaft angle?
    Online: 4 months ago
    😊 View Profile
    πŸ’¬ Send PM
    The Nor Star Kingfisher is a heavy boat for its size and the positioning of the motor and prop shaft angle certainly matter.
    I built one in 1972 powered by a DC Sabre marine diesel (1.5cc) and the engine was in the cockpit which made it heavy at the bow.
    I was disappointed by its poor performance in relation to other boats of similar dimensions, in some cases these being powered by 1 cc diesels.
    It never crossed my mind that I could have used "ballast" and the boat was sold on 7 months later at a greatly reduced price.
    "Fools rush in where experts fear to tread."
    Boaty😎
    1
    Dave Keech
    reilly4
    Warrant Officer
    Country: πŸ‡¦πŸ‡Ί Australia
    Online: 2 months ago
    😊 View Profile
    πŸ’¬ Send PM
    Ideally the centre of the weight needs to be near the middle of the boat.
    The original plan looked OK, maybe it required the batteries a little further back. The whole propulsion system did look a bit heavy for the boat.
    2
    Kipper
    Online: 1 year ago
    😊 View Profile
    πŸ’¬ Send PM
    You could reduce the angle by rotating the motor 180 & using gear or belt drive to the shaft, so the motor is sat over the shaft.
    2
    RNinMunich
    Fleet Admiral
    Country: πŸ‡©πŸ‡ͺ Germany
    Online: 14 minutes ago
    😊 View Profile
    πŸ’¬ Send PM
    Mornin' Ron,
    If you put the motor where the batteries are now - where will the batteries go? They weigh far more than the motor so moving them forward will push the CoG even further forward😲
    Re shaft angle; as flat as you can get it for the size of prop you want to use.
    This is to reduce the forward rotation moment of the thrust which tends to push the bow down. The further back you fit the motor the larger the angle will inevitably become due to the space needed for the motor and mount!
    BTW: Why two NiMh batteries?
    I would be tempted to change the set up to a brushless and a single LiPo.
    This will significantly reduce the total weight as wellπŸ‘
    You did say the boat is 'a heavy model'! πŸ˜‰
    Doug 😎
    2
    The Bugs are on the run 😊 ❄️❄️❄️ Get out and run those Sea Trials!! πŸ˜‰ Cheers Doug
    Ron
    Country: πŸ‡¨πŸ‡¦ Canada
    Online: 9 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    12 degrees according to this PDF but I may need to go a bit less say between 8 & 10.
    These photos give an idea of where I am going with these modifications. The prop shaft is too steep in this photo...
    1
    Ron
    Online: 9 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    This is a Norstar Kingfisher design. I want to place the motor beneath the rear hatch where the batteries sat. The CG was far to forward and this is a heavy model so it never ran very well. the motors ran hot even with a water jacket.
    I am moving the motor back, using a shortened prop shaft ,but what shaft angle will produce the optimum performance?
    Ron
