    propshafts lubrications
    6 Posts ยท 1 Follower ยท 3 Photos ยท 22 Likes
    Began 7 years ago by
    Recruit
    Switzerland
    Latest Post 8 months ago by
    Commodore
    Switzerland
    Mike Stoney
    Commodore
    ๐Ÿ‡จ๐Ÿ‡ญ Switzerland
    ๐Ÿ“ propshafts lubrications
    32 Views ยท 5 Likes
    Country: ๐Ÿ‡จ๐Ÿ‡ญ Switzerland
    Online: 8 seconds ago
    propshafts lubrications . . . and other concerns
    Hello friends,
    Once again small branches have blown into the water at our โ€œpondโ€.
    Saturday, I was at the pond with my grandson and two boats had wooden parts wedged in and the drive shaft was slightly bent . .
    Cutters Aline and Michelle (Commodore Graupner) now have to go to the shipyard!
    The โ€œReine des Ventโ€ is also finished and is waiting for a braided sail rope!
    And I wanted so much to continue working on the Mississippi steamer; well, what the heck!
    I'm retired ... and you have a lot of time on your hands if you're not married to a vacation technician like she!!!
    I love my wife and that makes it even harder for me.
    Greetings from a crazy hobbyist, your Michel-C.
    GregHiltz
    Chief Petty Officer 1st Class
    ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    58 Views ยท 3 Likes
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Online: 8 hours ago
    When I build my Shaft Tubes, I make a 1" long oil tube at r
    The front of the tubes and once per year I add 15 to 20 drops of 80-90 Gear Oil to the tube.
    LewZ
    Rear Admiral
    ๐Ÿ‡บ๐Ÿ‡ธ United States
    55 Views ยท 4 Likes
    Online: 5 days ago
    I just happen to have one of my boats opened right behind me so I took a photo of the "oiling tube". (I usually make my own prop shafts and tubes.)
    The easiest way (with copper/brass tubing) is to drill a hole in the tube where the fill chamber is, and solder a short fill tube to it. I also make a cap to protect the lube from contamination.
    As for the lube, I have used various type of greases and heavy oils. I found the best (and environmentally safe) way is to use petroleum jelly. Safe enough for skin wounds and gooey enough to work well in the stuffing box).
    Florida ๐Ÿ˜Ž, USA
    Lew Zee (LewsModelBoats.org)
    Mike Stoney
    Commodore
    58 Views ยท 1 Like
    Hi Maurice,
    Dies war vor 6 Jahren . . .bist Du noch dabei??
    Gruss Michel-C.
    Kipper
    Petty Officer 2nd Class
    57 Views ยท 5 Likes
    Online: 6 years ago
    Easiest way is to have your tube fitted with an 'oiler tube'.
    Maurice
    Recruit
    57 Views ยท 4 Likes
    Online: 5 hours ago
    Hi Guys, I just would like to enquire what s the easiest way to lubricate (fill) propshafts for a tug scale 1:40 ,meaning 10mm tube and 4mm rod.
    thanks for your help
    ๐Ÿ˜Š Maurice
