Current Website Support
86
Contributors
11
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ1
ยฃ3
ยฃ5
ยฃ10
    Followers
    Equipment wire
    by MouldBuilder ๐Ÿ‡ฌ๐Ÿ‡ง ( Captain)
    ๐Ÿ“ฃ
    Click To
    Follow
    13 Posts 12 Replies 0 Photos 18 Likes
    onetenor
    Sub-Lieutenant
    ๐Ÿ“ Equipment wire
    Online: 1 year ago
    Try here for your wire and anything else. Brilliant service and advice.
    https://www.componentshop.co.uk/๐Ÿ‘๐Ÿ‘
    ๐Ÿ”—
    jdr
    Recruit
    ๐Ÿ“ Equipment wire
    Online: 4 months ago
    Hi mouldbuilder, have you tried a company called CPC? They seem to have a sister company called Farnell.Maybe 1 L? Hope this helps you out.Good luck
    1
    timgarrod
    Master Seaman
    ๐Ÿ“ Equipment wire
    Online: 1 month ago
    Another good source of cable i use are network cables. pain to strip but each one has normally 8 cables inside.
    1
    http://alvastonpiratesmodelboatclub.co.uk/
    b111yboy71
    Recruit
    ๐Ÿ“ Equipment wire
    Online: 5 months ago
    I had an email from 'Haverlock' making the point that 'my' formula is no good for motors, etc. I agree. I did state it was for LED supply resistors. I found several references to this formula among which were 'Sparkfun' and the book "Introduction to Analogue Electronics". Any dissenters should take it up with RS - that's where I found it about 40 years ago. Case closed.
    2
    b111yboy71
    Recruit
    ๐Ÿ“ Equipment wire
    Hello, try looking for old 25way data cables at your local car boot sale. The cores are multi-coloured and very thin. Most LEDs only use a breath of current to drive them so you won't start a fire! Here's a tip about dropper resistors for LEDs: put them at the power supply end where you can tie them down securely. Also, the formula for finding the resistance you need is: R equals Volts(supply) minus Volts needed by LED (Vf) divided by the required LED current (If). So, say 12V supply, 2V LED wanting 15mA = 12-2=10/.015 = 666.667, so you'd use the nearest value above, which would be 680ohms. Easy! The size of the resistor in watts/milliwatts is found by I(current) times E(volts), so 10X.015=.15W, or 150mW. Hope I'm not teaching an old sea dog new tricks!
    Starting a new Firefloat - oh boy.๐Ÿ˜ฒ
    2
    MouldBuilder
    Captain
    ๐Ÿ“ Equipment wire
    Online: 3 hours ago
    Thanks for all of your help. I will check out all of the above and report back.
    Thanks again.๐Ÿ‘๐Ÿ˜Š
    2
    I promise I will finish a boat project before I start another......Maybe.
    gerritv
    Able Seaman
    ๐Ÿ“ Equipment wire
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Just to provide some more specifics on overall diameter, I have WW wire that is 30ga but the insulation adds variable amounts to that. E.g. one is 0.43mm dia, another is 0.75mm diameter.
    The solder-able wire that I use is 0.15mm diameter. That is available here: http://www.roadrunnerelectronics.com/epages/BT3782.sf/en_GB/...
    I still occasionally wire prototypes up using the Vector P173 wiring pencil :-)
    http://www.roadrunnerelectronics.com/epages/BT3782.sf/en_GB/?ObjectPath=/Shops/BT3782/Categories/Wire
    ๐Ÿ”—
    1
    Restoring a 1:72 HMCS Athabaskan (G07)
    RNinMunich
    Fleet Admiral
    ๐Ÿ“ Equipment wire
    Country: ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    Online: 29 seconds ago
    Redundant computer ribbon cables are also a good source, providing many colours. Even the connectors are useful for non essential stuff like lighting.
    ๐Ÿ˜Ž
    2
    The Bugs are on the run ๐Ÿ˜Š โ„๏ธโ„๏ธโ„๏ธ Get out and run those Sea Trials!! ๐Ÿ˜‰ Cheers Doug
    gerritv
    Able Seaman
    ๐Ÿ“ Equipment wire
    The inards of USB cables is very small, and stranded. Often available for few $ at thrift shops.
    I find WW wire (30ga) plenty robust for most things, used it a LOT in the 70's for backboards on mainframes. Solders very well. if the runs are long-ish then add a clip every few inches for support.
    If you need really really thin then magnet wire would be your next option. There is solder-able stuff available where the insulation dissolves under high temperature. insulation is otherwise quite robust.
    2
    Haverlock
    Sub-Lieutenant
    ๐Ÿ“ Equipment wire
    Online: 1 year ago
    Have a look for intruder alarm wire comes in 4 and 6 core and is stranded as opposed to solid wire which a lot of the telephone wire was ( dunno if it still is)
    https://www.ebay.co.uk/itm/Alarm-Cable-6-Core-White-Intruder...
    if you need thinner still ( and unless the wire is supported VERY well I advise against it ) use wire wrapping wire.
    https://www.ebay.co.uk/itm/0-25mm-Wire-Wrapping-Wire-30AWG-C...
    hope this helps
    https://www.ebay.co.uk/itm/Alarm-Cable-6-Core-White-Intruder-Burglar-Secuirty-Wire-PVC-Insulated/252492643054?hash=item3ac9bbfaee:m:mv4ZmI2-stkMj17vCG6Go4w:rk:3:pf:0
    ๐Ÿ”—
    https://www.ebay.co.uk/itm/0-25mm-Wire-Wrapping-Wire-30AWG-Cable-305m-New-Red-T4D5/123178150109?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D52543%26meid%3D17f03e5b33dd44069a6017a2c126df6e%26pid%3D100005%26rk%3D3%26rkt%3D8%26sd%3D121195610390%26itm%3D123178150109&_trksid=p2047675.c100005.m1851
    ๐Ÿ”—
    2
    "that's not a bug its just an undocumented creature." Sir Terence David John "Terry" Pratchett, OBE (28 April 1948 - 12 March 2015)
    Show 3 More Posts
