Motor suppression
Started by MouldBuilder
4 replies 7 likes 0 followers Last activity: 8 years ago
Motor suppression
Thanks Doug. This will help me understand capacitor values in the future. I now have an understanding of resistors, capacitors, ic`s (a little) and diodes. Transistors next😊
I have attached a picture of the site that confused me😎
Motor suppression
Hi Peter,
I guess these are ceramic capacitors.
224 mean 22 x(10 to power 4) in Picofarad (pF) = 220000pF = 220nF. Or 0.22µF.
I.e. the '4' means the number of trailing zeroes.
Don't know where you 'looked up' the 1nF (1000puff as known in the trade!😮)
The leading 2s must appear in the final value!
Thus 1nF would be marked 102 and 10nF 103.
47nF should be marked 473.
After the value code there is usually letter indicating the value tolerance; J, K or M indicating ±5%, ±10% and ±20% respectively.
So, to finally answer your question 🙄; I would use the 47nF capacitors. (=0.047µF)
Older ones may be marked .047.
Cheers, Doug
Liked by rolfman2000 and MouldBuilder and
Motor suppression
Thanks Martin. I have seen this and it seems to be generally a standard layout. My main problem is whether the capacitor already fitted by Krick is adequate as the positive to negative contact suppressor is usually 47nf but the ones fitted by Krick seem to be only 1nf.😊
Peter.
Liked by Martin555
Motor suppression
Hi mouldbuilder,
There is an article in the How to's on the home page (motor suppression)
I don't know if that will answer your question.
Martin.
Liked by MouldBuilder
Motor suppression
I could do with a little electronics advice please.
I have purchased two Krick motors with gearboxes for my Dusseldorf Fire Boat. I also bought the necessary capacitors for suppression. I have 47nf for across the terminals and 10nf for terminal to case. There is, however, a capacitor already fitted across the terminals which states a number of 224 on the casing. I have looked this up and it appears to be only 1nf, (1000pf). Is this acceptable to suppress this motor or should I change them to 47nf as per the instructions. Thanks.😊
Liked by Martin555
