Current Website Support
88
Contributors
9
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ1
ยฃ3
ยฃ5
ยฃ10
    Followers
    Air Sea Rescue Launch 123
    by Will-I-Am ๐Ÿ‡ฌ๐Ÿ‡ง ( Master Seaman)
    ๐Ÿ“ฃ
    Click To
    Follow
    14 Posts 13 Replies 4 Photos 11 Likes
    jbkiwi
    Rear Admiral
    ๐Ÿ“ Air Sea Rescue Launch 123
    Country: ๐Ÿ‡ณ๐Ÿ‡ฟ New Zealand
    Online: 10 hours ago
    If they are the same as Doug posted a little while ago, they only show total volts for NiMh (only a pos and neg plug). The only way you could get individual cell voltage would be to have the cells wired similar to LiPos with check/balance wires from appropriate points, but I don't know if there are any checkers readily available. You could re wire a pack to a multi plug so you could check individual cells with a multi meter perhaps. Doug will probably have a better idea being the tech man. The problem with NiMh cells is there can be large numbers in a 'pack' (as against LiPos which have purpose designed chargers and checkers with JST-XH leads for 1-10 cells) and if there is a dud cell in the middle you won't know till the battery keeps dropping its' charge quickly when not being used.
    DodgyGeezer
    Sub-Lieutenant
    Online: 13 days ago
    ".....If you are using NiMH or LiPo than I can also heartily recommend a little Capacity Checker/Monitor, available all over fleaBay for a few quid......The Checker can then tell you a bit more, e.g. if you've got a duff cell, which will collapse under load even if the other cells are still good!"
    Interesting. But, as far as I can see, these checkers only provide total voltage for NiMH - just like a voltmeter. The individual cell info is just for Lipo or LiFE. Or am I reading their adverts incorrectly?
    RNinMunich
    Fleet Admiral
    Country: ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    Online: 6 hours ago
    I heartily agree JB ๐Ÿ‘
    In fact you'll probably find that most commonly used 'inexpensive' (Chinese๐Ÿ™„) ESCs will only deliver 1 or 2A through the BEC.
    Even folks like Action Electronics / Component Shop advise against using them with their modules.
    No great demand around here for snow in Juneโ„๏ธ
    but if you'd like to check back around Christmas time .... ๐Ÿ˜€
    Cheers, Doug ๐Ÿ˜Ž
    The Bugs are on the run ๐Ÿ˜Š โ„๏ธโ„๏ธโ„๏ธ Get out and run those Sea Trials!! ๐Ÿ˜‰ Cheers Doug
    jbkiwi
    Rear Admiral
    Hi Doug, I always use a UBEC with power taken off before the ESC and disconnecting the BEC in the ESC if it has one. I fly planes as I've mentioned before, and most of us who do, don't trust the BECs in even the commonly used ESCs (maybe not the real expensive ones). They seem to have a habit of going up in smoke as they are mostly between 3-6A and it only takes a large servo jam up or similar to kill them, then kiss the plane goodbye. UBECs are available in much larger amperages as well to suit your max loading . I've never had a problem in around 12 yrs of electrics in planes and boats using this method, and you still have control even if the battery goes down to the minimum. (perhaps the ESC sucks too much power away from the BEC circuit trying to supply the greater demand of the motor in some low battery situations, thereby causing a lack of control,- ie motor,rudder, ie motor trying to go, but REC not getting power from BEC to tell it to, hence a stalemate,) - or in other words, the battery's too small for the job in hand. Selling snow to Eskimos, (sorry-Inuits) in your case, I know Doug, just my experience using UBECs.
    1
    RNinMunich
    Fleet Admiral
    Online: 6 hours ago
    My pleasure Ian,
    If you are using NiMH or LiPo than I can also heartily recommend a little Capacity Checker/Monitor, available all over fleaBay for a few quid. See attached pic.
    The car bulb trick is just to see how the battery reacts to a load.
    The Checker can then tell you a bit more, e.g. if you've got a duff cell, which will collapse under load even if the other cells are still good!!
    Happy sailing๐Ÿ‘ Cheers, Doug ๐Ÿ˜Ž
    Will-I-Am
    Master Seaman
    Online: 6 days ago
    Thanks for the reply Doug, I will use the idea of the car bulb to check next time just to see what is left in the battery.
    Regards Ian
    1
    RNinMunich
    Fleet Admiral
    Online: 6 hours ago
    Thanks for the memory jog Martin,๐Ÿ‘
    Reminded me to finish my experiments with Voltage Comparator chips coupled to an external LED ladder or 555 based LED flashing unit as a 'Low Battery' warning!
    Cheers, Doug ๐Ÿ˜Ž
    1
    RNinMunich
    Fleet Admiral
    Online: 6 hours ago
    "I had the rudder control on the Tx back to front ..."
    He he๐Ÿ˜‚ EXACTLY the same thing happened to me with my Sea Scout Ian.
    Had to think backwards on her first run๐Ÿ˜ฎ
    Re BEC! That sounds very logical.
    The internal regulator will need at least one volt more than the required output voltage (presumably 5V if it's like my 10A Vipers) to work.
    Another reason I prefer a separate RX battery ๐Ÿ‘
    When you check a battery OFF LOAD it will always have recovered a little and show a slightly higher voltage than it would on load!
    Check it when loaded with something like an old 5W car bulb and watch the voltage.
    At 6V the current will be around 800mA.
    The voltage will usually drop a little as the load is applied. But if it keeps on visibly dropping then the battery needs charging.๐Ÿค”
    Your motor will draw much more current of course, which accelerates the process.
    All's well that ... ๐Ÿ‘
    Cheers, Doug ๐Ÿ˜Ž
    Martin555
    Admiral
    Online: 6 hours ago
    Hi Will,
    I too like the idea of having a separate battery for the receiver as in the past I have had a main drive battery get extremely low, and by leaving the boat bobbing about in the water for a while it just had enough charge to pulse it in to shore.
    If the receiver was run from the BEC then I would not of had the power to do it.
    Martin.
    1
    Will-I-Am
    Master Seaman
    Online: 6 days ago
    Martin, yes too responsive I intend to reduce the rudder throw.
    Cheers Ian
    1
    Show 4 More Posts
