Electronics 43x esc
Started by octman
4 replies 2 likes Last activity: 7 years ago
Electronics 43x esc
Thanks chaps. You have provided everything I needed to know. Great.
Liked by Martin555
Electronics 43x esc
hi there, just an update. Electronize is around (in a fashion) although they don't advertise - Dave Mainprize, the owner of Electronize, is still running the Company. Although they aren't producing the 30 amp speed controller, I am lead to believe they are still doing the 43X which is a 15 amp one. How you go about purchasing I am unsure - however - if you do a web search you can come up with his telephone number/address.
John
Electronics 43x esc
Hi. These speed controllers are really excellent quality and can handle a high degree of voltage and amps. I use two in my vosper which each handle 24 volts. Be warned though you can seriously damage them if you reverse the polarity when connecting to the battery. There are two adjustments on them. I think one is sensitivity around the low speed response which improves greater low speed control. The other is speed range which gives you adjustment on the range of speed in relation to your radio stick throw. I have found these to be excellent high quality controllers giving excellent service and performance. You can wire in an anti reverse polarity circuit using a diode which is described in the instructions.
Kevin
Electronics 43x esc
I have just acquired a model that has 2 Electronize 43X esc’s. I realise these are an old design and the company is no longer around( I think) but the ecs’s Look in very good condition and they do work. Does anyone know the set up process for these as I cannot find any instructions or You Tube video.Chris
