Current Website Support
71
Contributors
6
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ1
ยฃ3
ยฃ5
ยฃ10
    Followers
    ESC PROGRAMMING
    by RHBaker ๐Ÿ‡จ๐Ÿ‡ฆ ( Sub-Lieutenant)
    ๐Ÿ“ฃ
    Click To
    Follow
    2 Posts 1 Reply 1 Photo 4 Likes
    mturpin013
    Commander
    ๐Ÿ“ ESC PROGRAMMING
    Online: 2 hours ago
    looks like a good idea' if I have trouble Ill this method, that's when I get to that stage!
    RHBaker
    Sub-Lieutenant
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Online: 6 hours ago
    Have struggled with brushless motor ESC programming and made up a small "flylead" to make it easier.
    I always run on a separate Rx power supply,
    so remove the red ESC power wire anyway. Rather that cut this off, now remove the plug entirely and bend the disconnected red wire back into the loom. Slide a piece of heatshrink over the loom, holding the red wire back.
    Fit the heatshrink so the tip of the connector just protrudes from heatshrink. Shrink the heatshrink in place and refit the two plug wires.
    Using a piece of scrap connector wire make up a fly lead that can be fitted into the plug and also into the end of the red wire.
    The plug can be fitted into a programming card to make adjustments. The flylead is easily removed and the plug refitted to the Rx when complete.
    This has the advantage of not wearing the plug slots and is quick to use.
    4
