battery drill motor
Started by peterd
53 replies 123 likes Last activity: 6 years ago
battery drill motor
Peter - There are other members much more qualified to give you recommendations on motors for your boats - actually tried using an old Bosch drill motor - high torque but very slow AND very high current draw - too much for a 40amp ESC on 12v
So was advising you very much on personal experience and knowledge gained afterwards.
Would suggest that you start another thread for advice specifically on motors/esc for the models you have - certain you will get a good response here
Liked by Joe727 and Martin555
battery drill motor
Ok and thanks. I might give it to a friend who does have a large but very underpowered tug.
Will go by the recommendations for the boat - cheaper in the long run as well for a better result.
Liked by Martin555 and redpmg
battery drill motor
The motors in those are usually very high current drain - so high powered ESC (expensive) needed and relatively short duration . Have heard of drills being used to power LARGE tugs - with the gearing enabling them to drive very large props (same as diesels in 1/1 scale) . Not sure how fast the motor would be as it would be most likely be wound for torque and not rpm - you need a high rpm motor for something like the Sea Commander to get a reasonable speed from it.
Liked by RNinMunich and Martin555 and
battery drill motor
I have an old 14.4v battery drill and am wondering whether any members have used a drill battery in their boats. Battery pack cactus so bought a new drill, just as cheap.
I believe it can be done with great results. Would need an ESC to suit but believe it is feasable, though with the battery it could be quite large.
I have two boats that need motors - one a 36in Mini Momo and the other an old Aerokit Sea Commander that i am doing up. Thanks.
Liked by Martin555 and RonH
